76 Z1 No Charge
- 76Zed1
30 May 2013 19:35 - 31 May 2013 00:03 #589980
by 76Zed1
76 Z1 No Charge was created by 76Zed1
I have searched the archives and have found plenty of good responses for no charge problems. Most of the posts I read though had the basic "three wire charging system" coming out of the stator. With tests that walk you though it. I have a background in electrical, but with any electrical system it is good to have something to refer to. I have ordered a manual but it is a week out. So if anyone has any pointers it would be very helpful.
The problem: No charge at any RPM. Have 12.6 volts at the battery whether the bike is running or not. After a short time the battery goes dead. I recharged the battery to test the charging system. Never got above 12v. It steadily depletes the battery.
Is this a differently phased regulator? if so does any know the readings you should get from the wires individually? And what readings should we have after the regulator?
Thanks for your time.
Last edit: 31 May 2013 00:03 by 76Zed1. Reason: Mistake
- Thank you received: 2829
30 May 2013 19:46 #589982
by 650ed
Replied by 650ed on topic 76 Z1 No Charge
Is your bike a 1976 KZ900? Ed
- DoubleDub
- Visitor
30 May 2013 20:24 #589987
by DoubleDub
Replied by DoubleDub on topic 76 Z1 No Charge
That doesn't sound like the correct stock stator wiring for a US '76 Kz900. Are you in a different country possibly? Otherwise the stator may have been swapped from a different bike?
I can dig up the testing routine for the stator out of my manual, but it's possible it's a regulator issue (although I think they usually allow the voltage to go too high when they fail).
- roy-b-boy-b
- Thank you received: 103
30 May 2013 20:56 #589991
by roy-b-boy-b
Replied by roy-b-boy-b on topic 76 Z1 No Charge
That seem to be a later stator. Someone changed engines. You can make it work. I had a 79 motor in a 77 frame and I made it work. Can't remember how. I rode the bike for three years and never had a problem.
A 76 is a KZ900 not a Z1.
Post a picture of the stator side of engine.
The following user(s) said Thank You: 76Zed1
- Motor Head
- Thank you received: 391
30 May 2013 21:40 #590000
by Motor Head
Replied by Motor Head on topic 76 Z1 No Charge
Yellow, Pink, and Blue are the three stator wires. Three phase stator. Externally regulated. You need to test those three wires. You can Ohm them any combo of the three should be .7 ohm, or better you can check ACvoltage from each two of the three. Should be 56 ACV. So then you know if the Stator is good or not.
- 76Zed1
31 May 2013 00:05 #590034
by 76Zed1
Replied by 76Zed1 on topic 76 Z1 No Charge
Yes it is a 76 z1. I am not sure if the kz and the z1 are the one in the same.
- Motor Head
31 May 2013 00:11 #590035
by Motor Head
Here in "File Base" is a wiring diagram. Here you will see what the wire colors are, why there are 5 wires in the harness. Which ones are Stator and which are the switches.
www.kzrider.com/filebase/doc_download/264-z900a45
- 76Zed1
31 May 2013 00:12 #590036
by 76Zed1
This was what I was looking for. I was getting 16.7-20.1 acV. Thanks for everyone who replied. Always been a bike owner but nothing with a following like the Kz riders. Posted a picture of the bike. Hopefully this answers any question whether it is a Z1 or a Kz.
Attachment image.jpg not found
- Motor Head
31 May 2013 00:32 - 31 May 2013 00:37 #590040
by Motor Head
Make sure that the wires themselves, going into the stator coils are not having a bad connection. There will be a splice between the actual stator coil winding wire and the colored wires. You could use the OHM function and do a wiggle test at the wiring.
See if you have the Combo Regulator and Rectifier assy. If still a single rectifier and a separate regulator, you would be wise to upgrade to the new combo unit.
z1enterprises.com is one source of the combo setup, oregonmotorcycleparts.com is another. They would also have a stator.
Last edit: 31 May 2013 00:37 by Motor Head.
- 76Zed1
31 May 2013 00:46 #590043
by 76Zed1
I did look, and it does have the separate regulator. I will look into getting the combo unit, it seems like the way to go. Thanks.
- Motor Head
31 May 2013 00:50 #590044
by Motor Head
Quite a few of the guy's have done a new wiring harness and spade type ATO fuses to upgrade the old wiring.
(OMR) Old Man Rock is one. Might have a look at his posts if interested. He has one on the Combo install also.
- roy-b-boy-b
31 May 2013 21:20 #590146
by roy-b-boy-b
Could you post a picture of the other side? Nice bike.
