Dyna S problems with different coil
  • high toned son of a bitch
  • high toned son of a bitch's Avatar Topic Author
29 May 2013 20:01
#589797
Hey guys, I need some help.
76 Z1 900, motor has some work done, blah blah
Previous owner converted to DYNA S pickup and coils. The pickup/sensor is the one with two pickups and the little magnet on the crank. No moving parts.
The coils got damaged, so I did what I had done before to a couple of other bikes (including my old KZ1000 shaftie)
I wired in a Dodge Neon coil. Fired up, was only running on two cylinders. Shut off, swapped out to another Dodge Neon coil, Fired back up, same thing. Had ANOTHER Dodge Neon coil, fire up, same thing. Was hittin on 1/4, but nothing on 2/3. So I came inside to eat, went back out, and now have NO spark.
I have a brand new gel battery at 180 cca. New cables, and I did a GSXR full suspension swap on this thing, so I had the entire harness apart and rewire job for my triples/hand controls. I am 99% certain I got everything right with that.
Funny thing though. Whenever I am trying a new electrical system, I have a test light hooked up to the battery, just to see if there is some excessive "dimming" whenever I try things, just to see if there is a short somewhere before it actually kills something. I noticed when I would plug the NEON coils in, the light would dim a good bit. Then I noticed that if I took the crank pickup plate out, the light would be fine until I grounded it. I stripped the harness back down and everything was how it's supposed to be. ALmost like it was drawing a bunch or shorting out.
It doesn't do that now, though.... (the light dimmming thing). THere was NO burning smells, no smoke, no nothing. The pickups on the DYNA don't look swelled, cracked, etc. They look new.
I have a feeling that the DYNA S doesn't like just "any ol coils" hooked up to it, and I fried it. Say it ain't so.
thanks all
  • loudhvx
  • loudhvx's Avatar
Re: Dyna S problems with different coil
30 May 2013 11:34
#589920
The Dyna S is rated for 3-ohm coils or higher. The Neon coils are likely .5 ohm to 1 ohm. You were running 3 times more amps than the Dyna S is rated to handle. I'm surprised it lasted that long.
Also, there is no dwell control on the Dyna S. It's just max-dwell all the time, even if the crank is not turning. The Neon cois are designed for a controlled dwell and/or current limited driver. Running them at full current for more than a second or two can damage the coils too.
You need 3 ohm coils, or you need to get two 2.5-ohm, 100 watt resistors to limit the current (one resistor in series per coil).
The following user(s) said Thank You: high toned son of a bitch
  • kimsmith4807
  • kimsmith4807's Avatar
01 Jun 2013 19:25
#590322
Yup, agree with loud. I was running the gray 2.2 ohm dyna coils as a factory replacement to my stock coils and when I upgraded to the dyna s system I spoke with the folks at dyna about using the gray coils. They said absolutely not, the dyna s needs the 3.0 ohm green coils. 3.0 ohm minimum I believe, I think the rule is you can go bigger but never smaller.
1981 KZ1000-K1 LTD
08 Jun 2013 10:06
#591310
So an update on the problem I created......
I got a set of BLUE dyna coils, that ohm out at 4.7 cold. Installed them and cranked but still no start. NO SPARK.
The Dyna pickup gets "warm" and I also noticed the coils were getting warm. This was over the period of about 10 minutes with the key on and cranking, looking for other problems (even though I know what the problem is, lol), cranking a little more, checking my connections, etc.
So in about 10 minutes of powered up but NOT RUNNING, the stuff got warm. Not hot, but warm to the touch. Is this normal?
ALso, I think I probably cant check anything with the pickup, but I put a test light TO POSITIVE on the signal wires from the pickup and both stay grounded constantly. SO my signal wires from the pickup are steady grounded, key on, key off, cranking, doesn't matter. Is this because I cant check it with a normal testlight, or is this confirming it is toasted? I have noid lights, but they are at my work.
Is there anything else I can check before I buy another DYNA S ????
Thanks all
  • Motor Head
  • Motor Head's Avatar
08 Jun 2013 11:46
#591320
Sounds like it let the smoke out.
Go to Dyna's Site and download there test, www.powercommander.com/downloads/Support...Manuals/DynaSTSG.pdf
08 Jun 2013 12:23
#591322
Has secondary loop been ohm-tested?
Perhaps a faulty connection in coil output tower due to incorrect attachment of the metal clip onto end of the plug wire.
Would assure integrity of the splice (or terminal) where Dyna-S's red wire is supposedly receiving battery voltage.
Good Fortune! :)
  • Old Man Rock
  • Old Man Rock's Avatar
09 Jun 2013 11:13
#591419
:blink:
Brand new Green 3 ohm coil measurements with my FLUKE meter...
* Not connected to spark plug wires, just the coils them selves.
Primary: 2.8 - 2.9 ohms
Secondary: 13.22 K ohms (k = thousands)
Secondaries with suppression wires and plug boots 29.02 K ohms
Insure it's wired correctly
Attachment DynaSBenchTest.JPG not found
Follow the link for the static alignments thus insuring your pickups are good.
Dyna S Static Testing...
Insure rotor/crank magnet is positioned correctly @ 1/4 TDC....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
09 Jun 2013 11:50 - 09 Jun 2013 11:51
#591427
high toned son of a bitch wrote: ...BLUE dyna coils, that ohm out at 4.7... NO SPARK...Dyna pickup gets "warm"..coils were getting warm...over the period of about 10 minutes with the key on...put a test light TO POSITIVE on the signal wires from the pickup and both stay grounded constantly. SO my signal wires from the pickup are steady grounded, key on, key off, cranking, doesn't matter...anything else I can check before I buy another DYNA S....
As probably already known --
The ignition coil's primary winding is grounded and ungrounded through the pick-up module.
Given a functional and properly wired ignition coil that's receiving sufficient battery voltage, the coil should fire whenever its primary winding becomes ungrounded.
When the magnet that's embedded in the rotor passes by the pick-up module, it's supposed to interrupt the ground of the ignition coil's primary winding through the pick-up module to the engine case. Thus, "signaling" the coil to fire.
With ignition ON, hand-turning the crankshaft (using the 17mm fake nut provided -- not the 13mm bolt head) should produce plug spark when the embedded magnet passes the pick-up.
Good Fortune! :)
Last edit: 09 Jun 2013 11:51 by Patton.
  • Motor Head
09 Jun 2013 12:34 - 09 Jun 2013 12:35
#591432
Old Man Rock wrote: :blink:
This is a great write up OMR, all except the Scotch Lock. Way better to do a correct connection. Either with the correct Bullet Connector to the Factory Female, or a Solder and Heat Shrink connection.
Last edit: 09 Jun 2013 12:35 by Motor Head.
09 Jun 2013 13:21
#591443
It's mentioned in the diagram, but perhaps important enough to again note in the photo.
Attachment omrdyna-Ssolderpreferred.jpg not found
Many stock wiring harnesses include unused female plugs for supplying switched-power to accessories, which suffice nicely for Dyna-S installations.
Such accessory plugs may be located under a side cover, or under the fuel tank, or inside the headlight shell. And are usually shown on the bike's wiring diagram.
KZr's FILEBASE includes many wiring diagrams for specific models.
Good Fortune! :)
13 Jun 2013 17:38
#592124
well an update,
it's fried. I got a set of Dyna coils and nothing, so I went through the tests you guys gave me (thank you) and it's not switching when the magnet rolls around. So i have ordered one and will use the proper coils this time. Lesson learned. Thanks for all the help guys!!!
  • Motor Head
13 Jun 2013 21:41
#592167
high toned son of a bitch wrote: well an update,
Take it that your lesson learned, and posted here on KZR, will help others from the same mistake.
So thanks for posting here. Everyone makes mistakes, but a smart person learns from them.
