Stator interchangeability
  • greenman43
  • greenman43's Avatar Topic Author
27 May 2013 08:06 - 27 May 2013 10:15
#589378
Hi all,
Looking to draw on (hopefully) some past experience here please.
My bike is an '80 Mk II, which at some point in its life has (presumably) its engine; this has been replaced by one from a '78 Z1R.
While I'm happy that I've got the lighter crank motor, I'd love to turn the engine into a Mk II- lookalike. As a consequence, I've purchased clutch and cam covers, and just recently picked up a generator cover and stator.
However, on looking at the parts fiches on buykawasaki.com tonight, I've discovered that the rotor / stator arrangement is completely different between these two engines. Worse, the bolts attaching the stator to the cover are different sizes for each, so there's no way it's going to be an easy bolt-up. If the mounting bolt PCD is different, perhaps there is room to install an adaptor plate, but it's starting to look like a big job ... I could always buy a 79-80 rotor I suppose, but that's just more money on what's already starting to look like a money pit, and I'm not even sure the crank taper is the same (rotor mounting bolt is a different diameter, too).
Does anyone else have experience of this conversion ?
Thanks in advance,
Brian
1980 Z1000 A4 Mk II
2007 ZX10R 'SL' (superlight)
1989 GPz900R
Last edit: 27 May 2013 10:15 by greenman43.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: Stator interchangeability
27 May 2013 09:09
#589381
Don't bother. You see the problem clearly.
  • greenman43
28 May 2013 06:58
#589548
Thanks mate, you may well be right :(
Brian
1980 Z1000 A4 Mk II
1989 GPz900R
