Kawasaki KZ750 Pick Up Pulser Coil Points Wire
  • lroberts
  • lroberts's Avatar Topic Author
26 May 2013 22:23
#589346
My first post here and looking forward to many more!
Recently I picked up a 1979 kz750 and I am attempting to reassemble the wiring. For the life of me I can not figure out where the blue wire coming out of the Pick Up Pulser Coil Points goes. Really new to this so I hope it is not a stupid question.
Any help on where this wire plugs in would be great. Pic even better!
Major big thanks in advance!
Larry
  • Rainman
  • Rainman's Avatar
  • and a little Kaw shall lead them
Re: Kawasaki KZ750 Pick Up Pulser Coil Points Wire
27 May 2013 00:43
#589362
Welcome Iroberts.
If your 79 KZ750 is the twin cylinder,stock it has points and the blue wire goes to the coil.
Attached is the wire diagram
Good luck,
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
  • lroberts
27 May 2013 13:14
#589409
Yep it is a twin. Thank you very much! Now I just need to try and make heads and tails out of the diagram :-)
  • lroberts
01 Jun 2013 20:56
#590338
OK still not having any luck. Could somebody take a picture of exactly where this blue wire plugs in?
Thanks!
  • martin_csr
  • martin_csr's Avatar
02 Jun 2013 11:34
#590431
The ignition coil is tucked under the fuel tank. You might be able to connect the wire without removing the tank.
The following user(s) said Thank You: lroberts
  • lroberts
02 Jun 2013 13:52
#590447
Thank you!
