ELECTRICAL
  • BEE
  • BEE's Avatar Topic Author
ELECTRICAL
25 May 2013 14:21
#589141
NEED HELP!
HAVE OWNED A 1977 KZ650B SINCE 1978! I STORE IT EACH WINTER WITH STABIL. AND MARVEL IN GAS AND
A LITTLE IN EACH CYL . THEN DRAIN BOWLS AND CLEAN OUT SEDIMENT. IN THE SPRING I USUALLY CHG
PLUGS AND INSTALL FRESH CHG BATTERY. IT STARTED RUNNING BUT POORLY. LIKE IT WAS DROPPING A CYL.
I PULLED PLUGS AND FOUND OUTBOARD L SIDE PLUG FOULED . GAS. I CHECK POINTS AND CLEANED WITH A
BUSINESS CARD. I TRIED IT AGAIN AND STILL SKIPPING. CK POINTS FOR SPARK AND L SIDE NO SPARK.
I CHECKED AND RESET POINT GAP. TRIED AGAIN AND NOW HAVE NO SPARK EITHER SET!!! I AM BAFFLED. I
CHECKED TO MAKE SURE THERE WAS NOT A WIRE CROSSED TO POINTS . ALL OK.. ANY THOUGHTS?
