Help for LTD 750 1982
  • Ralm
  • Ralm's Avatar Topic Author
24 May 2013 12:00
#589023
Hei
Theres no sign of life when i turn key on.
I was riding, stopped and when i hit START button bike just died.
Checked battery and ignition. Its ok.
What can be the problem anyone?
And where are fuse box located?
  • mopguy
  • mopguy's Avatar
Re: Help for LTD 750 1982
24 May 2013 13:24
#589025
Looks like a fuse is either blown or disconnected, I dont know where the fuse box is, but a good place to look for it is under seat or behind side covers.
  • Ralm
24 May 2013 13:59 - 24 May 2013 14:04
#589031
I did traced one wire from the positive and found a box with 2 fuses. However theres two plugins disconected from this wire. Is that it??
Second one wire whice goes from positive dont know where it ends.
Replaced but still noth
Last edit: 24 May 2013 14:04 by Ralm.
  • MFolks
  • MFolks's Avatar
24 May 2013 14:53
#589035
if your bike has the original, glass tubed fuses, one or more may have failed from age,current surges, or vibration. They are AGX in size, and most auto, and boating supply stores can get the fuses for you.
Most Kawasaki fuses are usually in a small,plastic compartment, with several wires leading into and out
  • MFolks
  • MFolks's Avatar
24 May 2013 14:58
#589037
You'll probably need 10,15 and maybe 20 amp fuses. On some Kawasaki's, the fuses will be near the air filter box.If you see signs of overheating(discolored fuse clips,melted wiring), think about upgrading from the glass tubed fuses to the type used in todays bike's and cars, the "Blade Style" fuses and fuse holders.
  • MFolks
  • MFolks's Avatar
24 May 2013 15:01
#589038
The small, two fuse holder is Kawasaki's power source for heated grips or vest.Your main fuse holder should have three or more fuses and clips for them in a plastic holder.
  • CoolerKing
  • CoolerKing's Avatar
24 May 2013 15:12 - 24 May 2013 15:13
#589039
I've had the ignition switch fail before when I was riding. That would cause a no power situation too.
Best bet is to grab a test light or multimeter and start at the battery and work your way up the line... Battery-fuses-ect..
don't forget to check the grounds too.
1978 KZ650-C2
1976 KZ400D-3 (sold)
Last edit: 24 May 2013 15:13 by CoolerKing.
  • Ralm
24 May 2013 15:18
#589040
Hei again. I replaced some of them with same amount of AMP but not as long as the olde ones were. I guess that doesnt metter since i cal pul out wiring which holds the fuse. But still no sign of live.
  • Ralm
24 May 2013 15:25
#589041
On the first picture fuses inside er 20, 20, 10 and it worked but it should be as descrived in fusebox 20, 10, 10.
On the second picture it is 20 and 10 and it worked. Inside box theres writen num 40.
  • Ralm
25 May 2013 09:03
#589113
Found these burnmarks. Can these couse this problem?
Its bronse colour. Should i replace this?
Attachment image_2013-05-25.jpg not found
  • Motor Head
  • Motor Head's Avatar
25 May 2013 10:51
#589124
Yes you need to replace those. That Red/ White wire is the Battery wire for your electrical.
Make sure you cut back to good wire that has not been heat damaged.
  • Ralm
25 May 2013 19:01
#589173
FIXED!! Thanks all.
