ignition switch or test suggestions
  • ramtough_63
  • ramtough_63's Avatar Topic Author
21 May 2013 19:38
#588590
ok simple plug everything in works fine. changed turn signal stems everything works great push all the wiring up in the headlight now now power nothing no lights just dead
pulll everything out no change still dead double check battery 12volts check all fuses good
what are the outside chances the switch took a dump?
have power to white wire turn switch on no power check continuity on off no continuity
switch on continuity between white and green any help greatly appreciated
Attachment 100_7684.JPG not found
Attachment 100_7687.JPG not found
Attachment 100_7688.JPG not found
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • mopguy
  • mopguy's Avatar
Re: ignition switch or test suggestions
21 May 2013 20:16
#588592
I had similar problems and did what MFolks suggested, to spray electrical contact cleaner in keyhole and turn key back off and on and if that did not work, it was time to get a new switch, my thread is ignition switch. Lucky me it woorked for me, I hope it works for you too.
  • ramtough_63
21 May 2013 21:20
#588610
when I put a test light on it I get no reaction if i use my multimetrer i get 12.8v DC
at both white whires turn the switch on no voltage anywhere
tried another switch (not sure its a good one) same reaction need some input
is there a way to use a jumper wire in the connector to eliminate the switch
for test purpoeses it was fine until stuffing everythin in to put headlight bulb in
i'm not convinced its the switch It's too coincidental.
could it possibly be in left hand switch control it was a little hinky feeling when
testing the turn signals and had to tighen a little could left hand control effect switch?
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • ramtough_63
22 May 2013 00:43
#588664
i guess throwin a 20.00 switch at it wont hurt but if anyone knows the actual
wiriin schematic for the switch i would love to figure out what each pole on the switch is supposed to vontrol or why I have 12.7-13. volts at the 2 white pins in the connector and it wont power a test light
any electrical gurus feel like splainin it to me it would greatly be appreciated
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
22 May 2013 01:03
#588674
If not already done, would check the wiring diagram in KZr's FILEBASE, which also includes a separate box showing the "Ignition Switch Connections."
www.kzrider.com/filebase/doc_download/269-z1000a2a
Good Fortune! :)
  • Motor Head
  • Motor Head's Avatar
22 May 2013 10:01 - 22 May 2013 10:16
#588717
If you measure voltage, it is different to measuring current. So even though you have 12v when no load is on the circuit, when the test light is applied you now have a load. So voltage may drop to nothing if you have bad connection. Now this assumes your test light works, and has good ground connection. Go back and test at the Main Fuse, get it to where you test light lights up on each side of the fuse, on the Metal Clips. Could be a bad fuse.
If you look at the wiring diagram, you will see the Ignition Switch chart on the bottom of the diagram. It shows which wires make contact when the switch is turned to its different positions. You can unplug the switch and take a jumper to make the connection as would the switch. Then you will know right away if it is or isn't the switch.
The switch can be disassembled, inspected, cleaned, etc.
There was a new member the other week who had a similar issue. Tried a new switch, didn't fix it, and was actually a lower voltage when On. So he measured anyway. It turned out that in the Head Light Bucket he had a loose wire, a ground I believe, he never has posted back his results.
Last edit: 22 May 2013 10:16 by Motor Head.
  • ramtough_63
22 May 2013 21:20
#588811
Thanks guys just got home gonna test some grounds then keep looking
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • ramtough_63
22 May 2013 22:02
#588812
34 minutes to resolve and that included reinstalling switch headlight bucket and signals
losing and finding those tiny screws lol
understanding that having 12 volts and no current under a load had me checking grounds in the headlight bucket everything checked good so I rechecked my fuses all good noticed slight play
in the fuse box and waahlaah loose wire tightened everything up and good to go
thanks guys would've stuck with the fluke bad switch without your input suprising to see
it was something I hadn't touched since last year
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • Motor Head
22 May 2013 22:20
#588815
Loose and bad connections are usually the problem. Glad you sorted it out without dumping needless $$$$$$$ :)
