ignition key switch
  • mopguy
  • mopguy's Avatar Topic Author
ignition key switch
18 May 2013 09:36
#588047
While working on my carburetors and tessting them out, my ignition key switch would work and then next time I turned key nothing worked, I thought maybe I blew a fuse, but they seem okay. Now the ignition key wont work anymore but if you play with it for a while she might work again and then wont work again.Is this a sign I need a new ignition key switch or is it a short or bad ground? Thanks for your input.
  • MFolks
  • MFolks's Avatar
Re: ignition key switch
18 May 2013 15:39
#588086
You can try some plastic safe electrical contact cleaner(I like the brand, De-Oxit) sprayed through the key slot & turn the key off and on several times. If no luck, it's time to replace the ignition switch. I'd contact www.z1enterprises.com and hear what they say. www.deoxit.com is the website for the cleaner/preservative.
Your bike's ignition switch is subjected to a lot of vibration, and if you have the habit of carrying the key on a ring with other keys, the weight may have increased the wear on the internal electrical contacts.
Never use WD-40 on motorcycle electrical contacts,connectors, or switches, as over time it becomes a nonconductor, more like insulation.
  • mopguy
18 May 2013 21:45
#588107
MF Folks thankyou for your advice, ignition is working again, now if I could get the carburetors to work properly, man I had no idea how difficult it is to have these carbs working properly, I must have cleaned them God only knows how many times. I put a Keysters new kit, did the clear tube test and they are just below line, two turns on idle mix, and she wont start unless I spray some quick start, and then she idles at 1000 rpm, but when I give throtle she seems to want to die. I noticed my float needle has no clip that attaches to float, it has a rod that goes up and down, is that okay or am I missing them.
  • Spectre1982
  • Spectre1982's Avatar
22 May 2013 01:20
#588679
I attached a picture to this post. Are you talking about the clip where the black arrow is? I'm pretty sure you need that. It loops over the tab on the float. When the fuel level drops, it pulls the float needle down and allows fuel into the bowl.
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
  • mopguy
22 May 2013 10:18
#588719
Yes, I dont have any of those clips on my float needles and was wondering if I need them in order for the float to work, they did not come in the carb rebiuld kit.
