NEW DYNA COILS SAME PROBLEM
- stroker220
16 May 2013 00:39
hello..just installed dyna coils on 79 kz-ltd 1000 spark on all 4 great checked it all 4 spark great...1 and 2 fire up and pipe get hot..3 and 4 have great spark but don,t fire...it seems as pipe does not get hot..left coil 1 and 4 right coil 2-3...can timing out cause this or shims wrong..and my 79 still has the points in it not the transistorized...new plugs new wire,s..and is there an easy way to check timing or buy book only...
thank you...
thank you...
Re: NEW DYNA COILS SAME PROBLEM
16 May 2013 07:55Would suspect fuel mixture issue and/or compression issue in #3 and #4.stroker220 wrote: hello..just installed dyna coils on 79 kz-ltd 1000 spark on all 4 great checked it all 4 spark great...1 and 2 fire up and pipe get hot..3 and 4 have great spark but don,t fire...it seems as pipe does not get hot..left coil 1 and 4 right coil 2-3...can timing out cause this or shims wrong..and my 79 still has the points in it not the transistorized...new plugs new wire,s..and is there an easy way to check timing or buy book only...
thank you...
Are the tips on spark plugs #3 and #4 wet with raw gasoline?
Adequate compression on #3 and #4?
Valve clearances on #3 and #4 within specs?
- flhwesty
17 May 2013 14:57
Check boots for cracks.
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
1977 KZ1000LTD
1978 Z1R
- turboking
17 May 2013 17:17
sounds like a fuel/carb issue :pinch:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- woodsy
22 May 2013 17:19
1. Check spark,
you have already so that's good
2. get a compression tester, all 4 cylinders have the same compression (give or take a bit)
3. if 1 and 2 are ok the its carbs or timing, if 1 & 2 are firing then the timing is good
4. that leaves the carbs -- take off float bowls and unclogg main jets
KZ 1000 B3 ltd - Imported from USA in 1994 - Live in Cornwall UK
- Jeff.Saunders
22 May 2013 19:56
Check the wires are going to the correct plugs.
! & 4 come from 1 coils, 2 & 3 from the other one.
If you want to check, pull the plugs out of the head, put them into the caps and lay on the head. Put a wrench on the end of the crank and slowly turn the engine. When the pistons come to the top of each bore, the plug for that cylinder should fire.
www.z1enterprises.com
Z1 Ent on Facebook,
