Anyone relocate the electric on your kz?
- Juicyk
- Who needs guages?
15 May 2013 12:58 - 15 May 2013 13:00
Just trying to get some ideas on good ways to relocate the electrical components so I can run without the side covers and get that minimal clean look.
Any pictures or suggestions out there?
Plans so far are to go kick start only so I think a small low cranking amp battery will work. Right?
-Kevin
-Kevin
Graphic Designer that likes to get out from behind the computer to get greasy!
Last edit: 15 May 2013 13:00 by Juicyk.
- loudhvx
Re: Anyone relocate the electric on your kz?
15 May 2013 15:06
You can hide most of it right to the bottom of the seat pan. The frame rails will obscure most of it, and will even partially hide a small battery. (The KZ400's have to have a t least a tiny battery to get the charging system working.)
Here's a photo we took while still working on it. You can see parts of the aluminum pieces that we used to mount the regulator, rectifier, and battery (before we painted it). The battery is a sealed lead-acid from a 50cc Honda Spree scooter.
Here's what the initial mock-up looked like under the seat. Everything just fits between the frame rails, and there is still some clearance before it hit the seat pan.
If you make a new seatpan and mount directly to it, it hides everything even more. I made mine so it would hinge up to work on the electronics. Use a long straight run of wires to allow for the twisting.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: Reifer, Juicyk
- Juicyk
- Who needs guages?
15 May 2013 17:10
WOW! thanks a lot that's awesome!
- bountyhunter
15 May 2013 20:54My only suggestion is don't do it.Juicyk wrote: Just trying to get some ideas on good ways to relocate the electrical components so I can run without the side covers and get that minimal clean look.
- Jrbrownie00
15 May 2013 23:24bountyhunter wrote:My only suggestion is don't do it.Juicyk wrote: Just trying to get some ideas on good ways to relocate the electrical components so I can run without the side covers and get that minimal clean look.
And why is that?
82' kz750 ltd.
- bountyhunter
16 May 2013 04:30I'm old so I subscribe to the school that says if it ain't broke, don't screw with it.Jrbrownie00 wrote:bountyhunter wrote:My only suggestion is don't do it.Juicyk wrote: Just trying to get some ideas on good ways to relocate the electrical components so I can run without the side covers and get that minimal clean look.
And why is that?
- Old Man Rock
16 May 2013 08:23
If you know what you're doing or have the ability too truly listen & learn from guys like Lou (electrical knowledge & experience) not a problem...
Lot of ppl will place the electrical in the tail section as well... Follow Lou's links to his electrical site... Excellent info there!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- CoolerKing
16 May 2013 08:52
1978 KZ650-C2
1976 KZ400D-3 (sold)
- Juicyk
- Who needs guages?
16 May 2013 16:49Old Man Rock wrote: If you know what you're doing or have the ability too truly listen & learn from guys like Lou (electrical knowledge & experience) not a problem...
Wouldn't happen to have that link handy would ya? Or Lou's account name?
- loudhvx
17 May 2013 11:19 - 17 May 2013 11:27Juicyk wrote:Old Man Rock wrote: If you know what you're doing or have the ability too truly listen & learn from guys like Lou (electrical knowledge & experience) not a problem...
That's me, but I don't have a ton of stuff specific for minimalizing electrics, but there are many custom diagrams in the Mattylight thread.
There are also some diagrams for making voltage monitors using 1 or 3 LEDs, on my main page
. Seems like you have most of what you need, for now. Most of the mechanical info is for 550's and inline-four 400's (not the twin).
We did convert a KZ400 twin to electronic ignition using the points as the trigger.
You can see we located the ignition module, and circuit board under the tank, between the coils, so it is completely hidden.
home.comcast.net/~loudgpz/GPZweb/Ignitio...heiModForPoints.html
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 17 May 2013 11:27 by loudhvx.
