coils
- flhwesty
coils
02 Jul 2006 12:18
My buddy has a bad coil in his 1978 kz650. Can he use a coil off a 1976kz900ltd on his kz650? Both sets are stock coils. He will replace both coils if they are ok to swap.
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
1977 KZ1000LTD
1978 Z1R
- wireman
- flhwesty
Re: coils
02 Jul 2006 12:24
I do not know, how would I find out?
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1977 KZ1000LTD
1978 Z1R
- wireman
Re: coils
02 Jul 2006 13:24
it should be marked on them.but if the 650 has points ignition i would think they are the same.
- wiredgeorge
Re: coils
03 Jul 2006 07:33
It won't be marked on the coils. Use a multimeter on Ohms scale at the lowest setting (X1 or X10). Put the probes on the two small lugs where the power and ignition connect to the coils. The impedence of the primary windings can be measured like this... you should get about 3.8 Ohms for both coils. Anything in the range of 3.2 to about 5 Ohms will work.
