Only firing on 3 cylinders
- Motor Head
Re: Only firing on 3 cylinders
09 Jun 2013 12:38
If 2-3 are not firing, but 1-4 are. I'd swap the coils around. Remember it is a Wasted Spark System. So if you have one bad plug or wire or cap, it can lose both on that coil.
- daveo
09 Jun 2013 13:07 - 09 Jun 2013 13:42
Had similar problem a couple times. Solved one when that carb's pilot circuit was cleared of obstruction.
Recently had malfunctioning Dyna 2000 ignition module. #1 & #4 not firing. Sent to Dynatek for testing and module was replaced under warranty. Larry Nelson at Dynatek has been very helpful more than once.
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 09 Jun 2013 13:42 by daveo. Reason: re work
- bromz
- 1981 kz1000 csr
09 Jun 2013 16:37
Well I'm 99.9% sure it's not carbs. I had them off once and they looked fine. All new plugs and wires so.....
- daveo
09 Jun 2013 20:57
When you say looked fine, did you blow air and carb cleaner through the carb pilot circuit? You would still have fuel at open throttle though. So maybe it is something ignition. Motorhead suggests swapping the coils, which would isolate the problem to something in that system. That is how I isolated the recent problem I was having to the Dynatek module, because the swap made absolutely no difference. Then I called Dynatek...
That is my two cents. Happy hunting.
- bromz
- 1981 kz1000 csr
09 Jun 2013 22:05
When I took the carbs off I only went through number 2 cause that was the only cylinder I was having issue with. Sure would be dumb luck to have pilot circuit plug up on 2 and 3 an lets say not 1 and 2. Either way I blew out number 2. Has to be ignition. I'm still in Florida so I won't find out till Wednesday.
- bromz
- 1981 kz1000 csr
15 Jun 2013 10:04 - 15 Jun 2013 10:06
well here I go, replaced the coil and low and behold same thing 2 and 3 were still cold! So started in the ignition cover opened up and everything was in tact. traced the 4 wires back to ohm out the pulse generators and guess what? The 4 pin connector wasn't seated and wasn't making good contact on the 2 and 3 wires. That explains why it was loosing power in the rain! Guess I have an extra coil now. So lesson learned. Go through everything before starting to buy parts!Bike fires right up and runs like a champ again. Thanks for all your help guys.
Last edit: 15 Jun 2013 10:06 by bromz.
The following user(s) said Thank You: bluejacobs
- nitrokrumpt
- she just looks rough now
27 Jun 2013 13:03bromz wrote: The 4 pin connector wasn't seated
where is this located exactly? pictures help!
1982 kz750-n1 spectre
