Only firing on 3 cylinders
  • boatdrinks
  • boatdrinks's Avatar
Re: Only firing on 3 cylinders
25 May 2013 10:42
#589121
I would think that if it were the coil that you would have the same issue on #4. Have you checked that you have sufficient fuel in the #2 carb? Could also be a compression issue as others have stated.
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
25 May 2013 10:49 - 25 May 2013 10:51
#589123
well i just ordered a dirct replacement off ebay for 46 bucks shipped(new in box). If this clears it up i will order another and replace both then have one for the shelf
Last edit: 25 May 2013 10:51 by bromz.
25 May 2013 11:37 - 25 May 2013 11:48
#589126
bromz wrote: So I pulled number 2 plug grounded it to frame and i had a nice blue spark. Second time I tried it no spark Third time no spark, Fourth time I had spark. So coil? I have already posted I have changed the plugs and wires so they are all new....
Intermittent spark could result from a defective connection where the coil output connects to the plug wire.
Perhaps the metal terminal is improperly fitted onto the end of the plug wire that inserts into the coil output tower.
Question -- Are the new Dyna spark plug wires solid core or suppressor style wires?
Good Fortune! :)
Last edit: 25 May 2013 11:48 by Patton.
  • bromz
  • 1981 kz1000 csr
25 May 2013 12:09
#589129
copper core. They are not suppresor wire cause i talked to dyna and they said I would have to put my old caps on or buy resistor plugs.
  • Motor Head
  • Motor Head's Avatar
25 May 2013 13:27
#589140
Have you tried swapping the two coils? This will tell you if the problem is indeed with the one ignition lead or not.
Did you ever do a compression test? Check you valve clearances? Look for vacuum leaks? If so I must have missed that post.
Hope you get it figured out, so you can get out and ride.
  • bromz
  • 1981 kz1000 csr
25 May 2013 14:33
#589145
I havent pulled the valve cover yet. As far as a vacum leak im sure im good but how would that cause a cylinder not to fire? I think I have it down to a stuck float closed gonna pull the carbs and check. Unless you think I should fight it and try to pull the bowl with the carbs in place.
  • bromz
  • 1981 kz1000 csr
25 May 2013 14:34
#589146
I also do not think compression is an issue this bike only has 22k on it and it runs like an animal down the road
  • bromz
  • 1981 kz1000 csr
25 May 2013 16:17
#589160
I pulled the carbs went thru#2 cleaned it up. put everything back together started her up 2 and 3 were hot right away 1 4 cold then i notice gas was pissing everywhere. shut her off tapped on 1 and 4 floats cleaned up the mess and fired her again no gas and they all seemed hot. gonna let her cool and try again in a bit and see if i had any luck
  • nitrokrumpt
  • nitrokrumpt's Avatar
  • she just looks rough now
06 Jun 2013 04:11
#591027
whats up? what was it? i sort of have the same problem over here.
1982 kz750-n1 spectre
  • bromz
  • 1981 kz1000 csr
07 Jun 2013 16:20
#591227
Well thought I had it fixed but must have been running on about 3 1/2 cylinders. I was riding over to my dads and half way there I lost a bunch of power. 60 was about my max. Well I limp it there and let it cool down and do a cold start and I am only runni g on 1 and 4 now. So I'm o. Vacation In Florida and won't get to mess with it till next week but I'm certain the coil finally failed. I have all new plugs and wired and the carbs are clean. I will reace the could when I get home.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
08 Jun 2013 05:06 - 08 Jun 2013 11:38
#591301
:unsure:
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 08 Jun 2013 11:38 by daveo.
  • bromz
  • 1981 kz1000 csr
09 Jun 2013 09:37
#591406
Not sure what your confused face means ? What I meant to say is I will mess with it when I get home. Can you give me anymore input.
