1977 kz400 Ignition Coil Replacement
- jona barish
10 May 2013 14:07
Hey all,
I may need to replace my ignition coil. What's the best replacement coil option (brand/supplier)?
I was looking at the coil on this page:
www.partsnmore.com/parts/kawasaki/kz400/?filters%5Bprice%5D=100
Recommendations would be appreciated.
Thanks!
Thanks!
'77 kz400
- CoolerKing
Re: 1977 kz400 Ignition Coil Replacement
10 May 2013 14:43
I used this one on my 76 KZ400. I needed to drill a hole in the stock mount because the mounting points on this one are closer together.
www.z1enterprises.com/ItemDetails.aspx?i...zuki&item=EM24-72451
1978 KZ650-C2
1976 KZ400D-3 (sold)
- loudhvx
10 May 2013 14:54
These are the same coil that CoolerKing listed, but with caps for the plugs.
I would try these (angled caps):
www.z1enterprises.com/ItemDetails.aspx?i...aps&item=IM01143-55L
or these (straight caps):
www.z1enterprises.com/ItemDetails.aspx?i...cap&item=IM01143-55S
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- jona barish
10 May 2013 15:01
Thanks guys. Are these the correct specs for the 77 kz400?
Someone directed me to this coil, which is 5 ohms:
www.z1enterprises.com/ItemDetails.aspx?item=DYDC8-1-single
'77 kz400
- loudhvx
10 May 2013 15:39
5 ohms would likely work without problems, but 4 ohms is what came stock.
The 4 ohm would probably match the dwell requirements better. The 5 ohm coil would probably make the points last slightly longer.
1981 KZ550 D1 gpz.
Other links.
Other links.
- jona barish
10 May 2013 16:51
Sweet. I'll order this one and see how it goes.
Thanks again
Thanks again
'77 kz400
- jona barish
22 May 2013 12:30
I installed the new coil and she fired right up. I didn't realize just how poor the spark was before; it's such an improvement.
Thanks again.
Thanks again.
'77 kz400
