Exploded Speedo
  • dnestvold
  • dnestvold's Avatar Topic Author
Exploded Speedo
08 May 2013 13:11
#586327
So last fall I managed to go down, I have a 83 KZ750-F1 the only real damage that I have is the speedo exploded, not sure how I ended up with just that but I'll take it. The problem I'm running into is that the only match that I can find is a rusted cluster set for %150, I would rather not put rusted parts on my bike since it is in good shape. Are there any others that would work for this bike? I am on a budget and of course always willing to use aftermarket parts. Any suggestions would be appreciated
Thank you
Derrick
83 KZ750F1
Re: Exploded Speedo
08 May 2013 15:55
#586354
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • MFolks
  • MFolks's Avatar
Re: Exploded Speedo
08 May 2013 16:14
#586360
  • martin_csr
  • martin_csr's Avatar
Re: Exploded Speedo
08 May 2013 16:16 - 08 May 2013 16:16
#586362
The 83 550-M1 Shaft has the same speedometer. A few other 550s have the same meter bracket & speedo cover. The 750 Spectre meter bracket & speedo cover look the same in the diagrams. All of them have the same speedo drive on the front wheel. So I guess you could use the speedo from the models mentioned, but that would be a guess. A difference might be the socket assy for illumination of the speedo.
25005-1198 SPEEDOMETER,MPH
1983 KZ550-M1 LTD Shaft METERS
1983 KZ750-F1 LTD Shaft METERS
25008-1049 BRACKET-METER
1983 KZ550-F1 Spectre METERS
1984 KZ550-F2 LTD Shaft METERS
14025-1562 COVER,SPEEDOMETER
41078-1013 GEAR BOX ASSY
too many models to list.
Last edit: 08 May 2013 16:16 by martin_csr.
  • dnestvold
Re: Exploded Speedo
09 May 2013 21:03 - 09 May 2013 22:30
#586636
I have found a few but the price seems to be way more than I want to spend. I have found a lot of aftermarket ones that are 1:1 1:2.... is there anyone that might know what I need for a ratio? or someone who might know how I can find out?
after talking to jp cycles tech support, I was able to find that I need a 2:1
83 KZ750F1
Last edit: 09 May 2013 22:30 by dnestvold.
