KZ1000 - Adding a turn signal circuit
  • gaillarry
  • gaillarry's Avatar Topic Author
06 May 2013 08:25 - 06 May 2013 11:24
#585945
Picked up a 82 KZ1000 in running condition but the wiring for the turn signals was removed. I need to add turn signals to make it road worthy. I'll be using LED lights.
The handlebar switch is there with the wiring but the harness wiring was cut off.
How would I add a separate turn signal circuit??
1977 KZ1000
1985 Gpz750
Last edit: 06 May 2013 11:24 by gaillarry.
  • MFolks
  • MFolks's Avatar
Re: KZ1000 - Adding a turn signal circuit
06 May 2013 16:03
#586001
Here's the Kawasaki factory shop manual, it's got the wiring diagram, so installing new turn signal wiring should not be difficult:
www.kawiworld.com/index.php?option=com_c...icle&id=77&Itemid=99
And here's some more information on the color codes:
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
  • gwolever
  • gwolever's Avatar
06 May 2013 17:13
#586009
My 82 KZ1000 (CSR) didn't have front turn signals or a headlight when I bought it. The front turn signal wires had been snipped, but were still connected through the wiring harness. I just connected new wires from where they had been cut to my new LED turn signals. I bought a new relay that was compatible for LED lights and hooked it up too.
Where were your wires cut? Are you able to get to them to attach new wires in order to connect your LED signals?
1982 KZ1000 CSR
  • gaillarry
06 May 2013 17:35
#586016
Wires were cut at the harness, probably easier to just add separate wiring.
1977 KZ1000
1985 Gpz750
