name this part
- lightitup
name this part
05 May 2013 15:34
hey so im not sure what these are who can tell me [img][URL=http://s1202.photobucket.com/user/joeg730/media/1367777709297.jpg.html][IMG]http://i1202.photobucket.com/albums/bb378/joeg730/1367777709297.jpg[/img][/URL][/img]
81 kz 550 ltd
- lightitup
Re: name this part
05 May 2013 15:36
could this be move to electrical it was my bad on it being posted here sorry
81 kz 550 ltd
- jacksdad
- 1979 kz 750 OUCH, IT SPARKED
Re: name this part
05 May 2013 19:32
Looks like it goes to the rectifier
1979 kz750 twin cyl.
- MFolks
Re: name this part
05 May 2013 19:56
The far right item looks to me, to be the aux fuse holder, so you could use heated grips or a vest in cold weather. The item on the left, may be the "Reserve Lighting System", designed to turn on the high beam at reduced voltage so you can get home, without blinding on coming traffic.
- trianglelaguna
Re: name this part
05 May 2013 20:20
motorcycle stuff...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- boatdrinks
Re: name this part
05 May 2013 20:24MFolks wrote: The far right item looks to me, to be the aux fuse holder, so you could use heated grips or a vest in cold weather. The item on the left, may be the "Reserve Lighting System", designed to turn on the high beam at reduced voltage so you can get home, without blinding on coming traffic.
:evil:
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
Madison, AL
- 79MKII
- Love Them Kaws!
Re: name this part
05 May 2013 20:27 - 05 May 2013 20:28
One on left is the "brakelight failure indicator switch". It's for the models that have the stop lamp light on the dash. Don't remember exactly how it works though....
The Kaw List:
Last edit: 05 May 2013 20:28 by 79MKII.
Re: name this part
06 May 2013 12:20
The diagrams for the 81 550Ltd list an Outage Indicator Switch. It looks pretty much the same as a Brake light failure indicator switch or Fuel Check Switch.
- lightitup
Re: name this part
06 May 2013 15:44
when i unplug it from the bike the light fuel stop lamp light goes off. so if its just the switch i might just bypass it
81 kz 550 ltd
- loudhvx
Re: name this part
06 May 2013 17:32
Left is brake-light failure flasher for the dashboard brake light indicator. It flashes when the bulb burns out.
Right is the accessory fuse box.
Both not necessary to run the bike.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
