diffrent kind of point set up
  • richard_oxon
  • richard_oxon's Avatar Topic Author
04 May 2013 00:35
#585566
No eBay APP ID and/or Cert ID defined in Kunena configurationHas anyone ever used a set of these , or would you not bother and just go with the dyna ?
** KZ1000 B3 1979 ** 1015cc wiseco pistons 33 smoothbores ported head 410 cams
** KZ1000 A1 1977** 1075 wiseco pistons 438 megacycle cams ported head rs34 flat slides
  • Motor Head
  • Motor Head's Avatar
Re: diffrent kind of point set up
04 May 2013 00:40
#585567
Personally, I wouldn't. Can't see any advantage to points except ease of replacement if your Ignition quit. Electronic is on everything, and I mean everything now. Why turn back the clock?
The following user(s) said Thank You: richard_oxon
04 May 2013 01:15
#585569
I've always installed my own points since my bike was new and they work just fine. I would not switch to Maxi-dwell because some of the claims in their ad are bogus (i.e. "Stock points bounce at 2,000 rpm"; "All electronic ignitions retard at least 1 degree for every 1,000 rpm the engine turns. This Maxi-Dwell does not retard at all"; etc.). Also, is Maxi-Dwell still in business? I don't think they are, so if their products really offer an advantage why did the company fold - there are still tons of vintage bikes out there using points. If I was going to switch to a different ignition system I would go to electronic ignition - probably using a setup off a later year Kawasaki rather than Dyna as the Kawasaki ignitions reportedly draw less current. Ed
The following user(s) said Thank You: Motor Head
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
04 May 2013 07:39
#585581
richard_oxon wrote: Has anyone ever used a set of these , or would you not bother and just go with the dyna
Interesting!!! Thought about going Electronic.... but will see if anyone has actually used these and what they thought.?! :unsure:
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
  • turboking
  • turboking's Avatar
04 May 2013 08:04
#585585
:blink: uses g m points :huh: .......keep what you have if you want points :dry: ...... dyna is the way to go.... you can buy a new dyna s for $123.00 on flea bay
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • turboking
04 May 2013 08:08
#585586
1985 GS 1150E
1983 GS 1100E
  • turboking
04 May 2013 08:21
#585587
:unsure: i worked on bikes that used the "maxi-dwell" points in the 70's before the optical martek, and magnetic boyer, dyna's came along . they will turn a little more rpm than stock before bouncing, but who cares .. Dyna is the way to go......Maxi-Dwell , :pinch: A little better than stock.... :dry: waste of money IMO....
1985 GS 1150E
1983 GS 1100E
  • richard_oxon
04 May 2013 16:34
#585643
Thanks for the response everyone , I know it was age old but different. Good to see other peoples views on it .
