77 electrical run a boost sensor/sender?
- Hollywoodmx
30 Apr 2013 22:58
I was keen on a digital boost gauge and which obviously has a sensor. The sensor is 3 wire, power, ground, signal. Think the old 77 electrical is up to the task? There wont be any electrical noise unique to a motorcycle (vs a car) that would inter-fear with the senders signal?
Also thinking the electrical wire to the gauge wont be subject to binding as with the mechanical plastic tube.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- Motor Head
Re: 77 electrical run a boost sensor/sender?
01 May 2013 00:49
Can't see having much of an issue, just route the wiring away from the secondary ignition. Depends on the sensor what the signal voltage will be, but it will be a frequency, HZ, so it could pick up RFI. If your using a Injection system, check that you have No AC voltage in the system. Leak at the rectifier diode will cause that, AC ripple.
- Hollywoodmx
01 May 2013 10:32 - 01 May 2013 10:33
Thanks man. No injectors currently but I do have a low pressure fuel pump though.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 01 May 2013 10:33 by Hollywoodmx.
- fortunebrass
06 May 2013 08:20 - 06 May 2013 17:04
I just got sent on a permanently long hike away from the site.
Last edit: 06 May 2013 17:04 by Patton.
06 May 2013 08:35 - 06 May 2013 18:28
Thanks!
Last edit: 06 May 2013 18:28 by 650ed.
- loudhvx
09 May 2013 14:47]fortunebrass wrote: I just got sent on a permanently long hike away from the site.
Nice, Patton. :laugh:
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
