four way problem
  • flying dutchman
  • flying dutchman's Avatar Topic Author
four way problem
30 Apr 2013 11:31
#584903
all elect. on my bike work except the four ways, only left flash. 79 kz1000 ltd. where should i start looking? im thinking inside switch on bars????
flyingdutchman
79 kz-1000 ltd left to me by my best friend!!
it came in four boxes, frame and engine
i look much better with my helmet on, its full face.
  • MFolks
  • MFolks's Avatar
Re: four way problem
30 Apr 2013 15:01
#584944
I'd open up the handlebar switch pods(both sides), looking for corrosion, or failed/failing solder joints, as the older bikes are starting to show this problem. Also replace the silver can flasher relays(both), as they go bad after a few years. One controls the 4 way flashers, the other does the turn signals. The more expensive electronic versions will handle LED and incandescent bulbs.
  • MFolks
  • MFolks's Avatar
30 Apr 2013 15:03
#584945
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
The following user(s) said Thank You: flying dutchman
