73 Z1 No Spark Dyna S Pickups
  • Yorkie
  • Yorkie's Avatar Topic Author
27 Apr 2013 21:12
#584318
Newbie to the KZ forum. Just picked up an early Z1 that does not run. It's fitted with a Dyna S ignition pickups and I am not getting any spark at all. I think it's correctly wired as the red wire is spliced into the yellow/red wire and the other two wires to the coils. I am not sure that the bike has ever ran with this setup so could anyone guide me through a troubleshooting process? I have a multi meter but electrics are a bit of a mystery to me.
Thanks
Kevin
Long Beach, CA
'72 Z1
  • kzz1king
  • kzz1king's Avatar
Re: 73 Z1 No Spark Dyna S Pickups
27 Apr 2013 21:24
#584322
Check Dyna's website. They have trouble shooting docs there, used to anyway.
Wayne
Home built KZ1000 turbo setup
  • MFolks
  • MFolks's Avatar
27 Apr 2013 23:19
#584353
Check the supplied "Splice" that Dyna uses for the power source, as it can allow corrosion at this connection. The best way is to use solder, and then cover it with heatshrink tubing.
  • Yorkie
28 Apr 2013 11:47
#584425
I have power at the yellow/red wire splice. what readings hould I be seeing at the coils?
Thanks,
Kevin
'72 Z1
  • Old Man Rock
  • Old Man Rock's Avatar
28 Apr 2013 12:16 - 29 Apr 2013 09:05
#584434
Follow the guide for "Static", will tell you if pickups are operating correctly.
Confirm/measure Red (red/yellow) is ~ 12Vdc -> 13.5Vdc when ignition switch turned on.
Attachment DynaSBenchTest.JPG not found
Static Testing:
Dyna Installation Guide
Dyna T-Shoot:
Insure rotor magnet is pointing left when TDC 1/4
Confirm that coil primary is not touching/arching to grounded frame on the post (use nylon or shrink tubing post on the coil mounting posts)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 29 Apr 2013 09:05 by Old Man Rock.
  • boatdrinks
  • boatdrinks's Avatar
28 Apr 2013 18:37
#584501
I seem to see/hear a lot of guys having trouble with those. Glad I stuck witness points.
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
  • zukdave
  • zukdave's Avatar
28 Apr 2013 19:33
#584509
Have a buddy with a 78 1000 and he's on his third Dyna S in a year.
Dyna keeps warr. them so he keeps using them even
after being stuck out late at night.
Tight a$$ will not spent the money on a factory elec.ign. like I keep tellin him.
Next time he needs a 2 am trailer ride gonna tell him I'll come get
he when he has the right shit in his hand.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
28 Apr 2013 20:53
#584522
the vast majority of Dyna-S failures are caused by the bikes charging system.
Bad battery, bad regulator, or margin wiring - all can cause high or low voltage spikes.
With many of the electronic ignitions, not only is high voltage bad, but low voltage is as well.
It's well worth checking the regulator to ensure it's working.
It's also worth checking the voltage at the coils - with older harnesses on bikes that've been sitting for years, the corrosion on various contacts in connector blocks, ignition and kill switches limit the voltage. If the coils are only getting 10v, then the ignition is going to as well.
Running the bike with a bad battery can also cause the charging system to constantly push more voltage through the electrical system and damage the ignitions.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • zukdave
  • zukdave's Avatar
29 Apr 2013 00:51
#584575
Jeff the battery may well have been his issue
as he did have a marginal battery for a while.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • KZB2 650
  • KZB2 650's Avatar
30 Apr 2013 14:04
#584929
Had really good luck for 23 years with my 1st Dyna set up so that's why I'm going to trust em with a second. One of the pick ups blew on mine for some reason and I hope the problem is not still there waiting to get the next one.
Been running the points for several years now and have no spark after a re build so its back to a new Dyna for me.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
