Fuse for Z1B
  • boatdrinks
  • boatdrinks's Avatar Topic Author
Fuse for Z1B
25 Apr 2013 22:40
#584039
Would someone be so kind as to confirm what the amperage rating for the one fuse for the whole bike is. My friend is convinced that Z1E recommended a 20 amp fuse. Seems a little small to me.
Thanks!
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
  • MFolks
  • MFolks's Avatar
Re: Fuse for Z1B
25 Apr 2013 22:48
#584042
some of the FI bikes have a 30 amp fuse(mine does), but try a 20 amp fuse for your bike,but read if possible the marking on the old fuse, as you don't want to burn up the wire harness due to overloads.
These fuses are AGX in size,most auto parts and boat supply stores can get them for you. AGC size won't fit, as they are longer in length.
Re: Fuse for Z1B
26 Apr 2013 00:14
#584046
The main fuse on a KZ650 is 20 amps. It's possible the Z1B is the same. Ed
Attachment 00000_2013-04-25.jpg not found
Re: Fuse for Z1B
26 Apr 2013 01:42
#584051
boatdrinks wrote: Would someone be so kind as to confirm what the amperage rating for the one fuse for the whole bike is. My friend is convinced that Z1E recommended a 20 amp fuse. Seems a little small to me. Thanks!
20 amp -- no larger -- and don't use time delay ("slo-blo") fuses.
www.kzrider.com/filebase/doc_download/262-z1ab-us
Good Fortune! :)
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
Re: Fuse for Z1B
26 Apr 2013 02:32
#584056
20 Amp is correct. Pg 23 of a Z1B's owners manual states 20 amp fuze, no larger.
Blue 1975 Z1B
Red 2009 Concours 14
  • boatdrinks
Re: Fuse for Z1B
26 Apr 2013 08:12
#584066
My thinking was the same as Ed's. How could the 20 amp be sufficient for the whole bike since our 650s have a 20 and two 10s.
Thanks for the info guys. Apparently the parts break down for the Z1B just shows the fuse not what size the fuse is. I didn't look myself.
Charles
Madison, AL
  • Z1Driver
  • Z1Driver's Avatar
Re: Fuse for Z1B
26 Apr 2013 22:42
#584185
boatdrinks wrote: My thinking was the same as Ed's. How could the 20 amp be sufficient for the whole bike since our 650s have a 20 and two 10s.
I have a good running Z1B which has gotten along just fine using one 20 amp fuze for 38 years. :laugh:
Blue 1975 Z1B
