Stock brake light switch and a Brembo Radial MC??
- Killman
- Now with 99% more ducks
23 Apr 2013 01:01
I finish my current bit of contract work at the end of the month and, after a few months of 6 and 7 day weeks, I'm looking forward to "finishing off" my little project.
Which inevitably means that all of the little things that I forgot, didn't realize, or just didn't factor in are rearing their ugly little heads.
So anyone have any advice on fitting the stock brake light switch from my '83 kz440 ltd to a Brembo radial master cylinder?
1983 kz440 ltd
Quack
Quack
- MFolks
Re: Stock brake light switch and a Brembo Radial MC??
23 Apr 2013 01:06
Front brake switch? Look at these switches from K & S:
www.kandstech.com/index.php?page=brakeswitches
Some are plumbed into the brake line, using pressure to actuate the switch, others use a spring, like rear brake switches do.
23 Apr 2013 01:10 - 23 Apr 2013 01:11
Last edit: 23 Apr 2013 01:11 by Patton.
- Killman
23 Apr 2013 01:13 - 23 Apr 2013 01:17
Thanks, I like the idea of just plumbing in a hydraulic unit and forgetting about it, but I have a feeling that the spring-loaded units might be easier to adjust/maintain.
I was hoping to use the stock unit, if possible, though.
Haven't given this much thought, except for those random moments when I thought "Hmm... better figure out that brake light switch" so I'm a little fuzzy on the matter, but how do I install those banjo bolt hydraulic numbers?
1983 kz440 ltd
Quack
Quack
Last edit: 23 Apr 2013 01:17 by Killman.
- MFolks
23 Apr 2013 01:33
Usually a longer bolt for the "Banjo" fitting is used,with the switch plumbed into the fitting.
