Write nuts our butt slices.
- jacksdad
- 1979 kz 750 OUCH, IT SPARKED
21 Apr 2013 11:13
Wanting some opinions here, what holds up better when rewiring behind the light, but splices, our small wire nuts?
1979 kz750 twin cyl.
Re: Write nuts our butt slices.
21 Apr 2013 11:48
Bullet connectors. Small, easy to use, and will last for decades. Ed
- MFolks
21 Apr 2013 16:09
www.easternbeaver.com
sells many electrical items used on our bikes.
The following user(s) said Thank You: bluezbike
- jacksdad
21 Apr 2013 21:28
Yeah I thought about bullet connectors, now to figure out the blinkers.
- donthaveakawman
- baldy110
22 Apr 2013 17:48donthaveakawman wrote: splice, solder and shrink wrap.
Wow you got one correct. Wire nuts are for residential wiring not motorcycles.
- MFolks
22 Apr 2013 18:10
When I do wiring modifications on my bike(new horns,running lights,& more visability to the rear), I use heatshrinkable splices, as they are waterproof, and resist vibration. There are two types;one that you crimp on the wires and then shrink down, and the other one that contains solder in a heatshrinkable splice.
More information in the video's:
(Heatshrink Terminal Installation)
(Heatshrink Terminals And Connectors, AAA Protection)
(Heatshrinkable Crimpable Terminals)
Wire Terminal Crimping Tools
www.pbase.com/mainecruising/wire_termination (The Good, Bad, & Ugly of Crimpers)
crimpsupply.com/
crimpsupply.com/
- MFolks
22 Apr 2013 18:15
Wire Termination Insulation & Sizes
Terminal Insulation Color Wire Sizes
RED
22-18 gauge wire
BLUE
16-14 gauge wire
YELLOW
12-10 gauge wire
RED
8 Gauge
The ring terminal holes comes in many sizes, from #4 up to 1/2" in most cases, it's a matter of finding the tightest fitting hole to fit the fastener for the termination.
American Wire Gauge(AWG) is backwards to what many people think; that is 22 gauge is many times smaller than 10 gauge even though the number is bigger.
Sherco Auto parts www.sherco.com
NiAc ™ Heat Shrink Butt Connectors
Adhesive Lined—Moisture Proof Low Temp. Cross-Linked Ionic Polymer.
10 Pack 100 Pack 1000 Pack
HSNRBS 22-18 Gauge Red NiAc™ $3.50 $24.95 $174.95
HSNBBS 16-14 Gauge Blue NiAc™ $3.50 $24.95 $174.95
HSNYBS 12-10 Gauge Yellow NiAc™ $4.25 $ 39.95 $269.95
NiAc Assortment SBA-HSN
30 Red, 40 Blue, 30 Yellow
$29.95
RED
22-18 gauge wire
BLUE
16-14 gauge wire
YELLOW
12-10 gauge wire
RED
8 Gauge
$29.95
