ACCEL U-GROOVE SPARK PLUGS
- daveo
21 Apr 2013 07:22 - 21 Apr 2013 20:17
After hunting through past posts, I found reference to Accel 142 U-Groove spark plugs; once a top-choice for the old Kaws.
Any opinions, considering today's alternatives? :huh:
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 21 Apr 2013 20:17 by daveo.
- bountyhunter
Re: ACCEL U-GROOVE SPARK PLUGS
21 Apr 2013 20:37 - 21 Apr 2013 20:38
I use NGK B6ES. The four cyclinder bikes use B8ES. I think the Nippon denso plug is ND W20ESU for the twins?
Last edit: 21 Apr 2013 20:38 by bountyhunter.
- daveo
21 Apr 2013 23:37
Dear bountyhunter,
Please see post #354645 from 3 years, 1 month ago. By golly, you were part of the subject conversation back then...what a trip!
I was so inspired by the enthusiasm expressed for that spark plug, I had to locate a set for my bike to try out. The Accel 142's should arrive by mid-week, along with some nice riding weather.
Just wonder if that old thread has relevance now, what gap I should start with, and what torque to snug them down to?
- baldy110
- daveo
22 Apr 2013 17:04 - 22 Apr 2013 17:06But what about all that fatter, wider, hotter...spark stuff?
Last edit: 22 Apr 2013 17:06 by daveo. Reason: add
- KraZyRIDER
22 Apr 2013 21:45daveo wrote:NONE? :ohmy:
...I agree with Baldy there. In the 70's I did a lot of experimentation with plugs on my old triples. Single ground, double, triple, quad ground! Didn't matter. Fat electrode, thin electrode. Didn't matter. Gold, Platinum, whatever! Didn't matter.
...as a matter of fact, the only thing that did matter, was the correct heat range! Yes, some plugs lasted longer than others. But, heat range was the thing to getting everything out of that engine, while not hurting it!
...do you really think that a volatile mixture of fuel and air can tell the difference between the shape of the spark that is igniting it?
...heat range, tantamount to performance and protecting your engine.
...I had a friend that believed since he went up three jet sizes, he had to go up three heat ranges. Blued the shit out of his pipes, then it holed his pistons.
Mean Green Speed Machine!
1979 KZ 650-C3 (Cafe Project)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
- daveo
23 Apr 2013 01:12 - 24 Apr 2013 22:44
Great feedback guys...THANKS! :blush:
Received in the mail, installed in engine. Cranked, cranked, and finally started. Ran pretty good until a few miles, then the engine began to run erratically, sputtered, and almost died.
I put the old ones back in, fired right up, and ran with no issues. Maybe a bad batch, or just old (but new in the old packaging). I'm skeptical now. :blink:
Last edit: 24 Apr 2013 22:44 by daveo. Reason: updated
- zukdave
28 Apr 2013 19:44
Trick of the week shit doesn't always work.
Factory spent who knows what and put in NGK B8ES plugs for a reason.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
