Removing the starter and battery
  • DouglasBoyo
  • DouglasBoyo's Avatar Topic Author
20 Apr 2013 18:06
#583327
Hi. I have a 1978 KZ 650 B2 and I want to remove the electric starter and battery and make it kick only. I heard the bike will still run the headlight and brake lights with a condenser or something. It is currently not running and I am redoing the wiring after being taken for a ride by a local shop.
If anyone has done this and had success, please let me know what was done and what parts you had success with.
Thank you!!
  • MFolks
  • MFolks's Avatar
Re: Removing the starter and battery
20 Apr 2013 19:35
#583346
Find a forum member named "Loudhvx", as he's done this to several bikes. The Kz650's came in many flavors, some had the abilty to make into kick start bikes, but most needed the battary as the charging system was not designed to do this. It will depend on the model you've got and the year.
Kawasaki KZ650 Charging system information
Below are the systems used on the 650s. As you can see there are basically 3 different systems used, 2 of which are 3phase which use 3 wires and the other is single phase which used 2 wires.
First gen. uses 3 wires
1977 B1 standard...3phase excited field
1977 C1 custom.....3phase excited field
Second gen. uses 2 wires
1978 B2 standard...1phase permanent mag
1978 C2 custom.....1phase permanent mag
1978 D1 sr.........1phase permanent mag
1979 B3 standard...1phase permanent mag
1979 C3 custom.....1phase permanent mag
1979 D2 sr.........1phase permanent mag
1980 E1 LTD........1phase permanent mag
1980 F1 custom.....1phase permanent mag
1980 B4 standard...1phase permanent mag
1980 C4 custom.....1phase permanent mag
1980 D3 sr.........1phase permanent mag
Third gen. uses 3 wires
1981 D4 sr..............3phase permanent mag
1981 F2 ................3phase permanent mag
1982 F3 ................3phase permanent mag
1983 F4 ................3phase permanent mag
1981 H1 csr.............3phase permanent mag
1982 H2 csr.............3phase permanent mag
1983 H3 csr.............3phase permanent mag up to KZ650DE052650
Fourth gen.
1983 H3 csr.............New type 3phase permanent mag starting at KZ650DE052651
  • CrazyDuck
  • CrazyDuck's Avatar
20 Apr 2013 20:30 - 20 Apr 2013 20:33
#583357
Want to ditch the battery? Get one of these! :laugh:
Minimum 15volt and 50,000uf Capacitor. You can hide it wherever you want.
Bike will be kick start only but you can't have the headlight on when starting it.
My 900 starts first kick every single time.... unless I forget to turn the headlight off.
Here is what I got:
Attachment Battcapacitor.jpg not found
Attachment IMG_0151.JPG not found
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
Last edit: 20 Apr 2013 20:33 by CrazyDuck.
  • bluej58
  • bluej58's Avatar
20 Apr 2013 20:41
#583359
MFolks wrote: Find a forum member named "Loudhvx", as he's done this to several bikes. The Kz650's came in many flavors, some had the abilty to make into kick start bikes, but most needed the battary as the charging system was not designed to do this. It will depend on the model you've got and the year.
Fourth gen.
Which type works ?
78 KZ1000 A2A
20 Apr 2013 22:23
#583369
I can't speak for the rest of the models, but the KZ650-B1 and C1 must have a battery because of the 3-phase excited field generators. Without a battery they will not run. Ed
