KZ1000 HT Leads
- woodsy
What i want to do is is put new bright yellow HT leads on the stock coils for my kz1000, the question is :-
Can i screw carbon leads into the stock coils, then what about suppression, i was hoping that i could have ends that fit straight onto the plugs with a rubber boot, basically like a car, so if anyone has any answers please help
KZ 1000 B3 ltd - Imported from USA in 1994 - Live in Cornwall UK
- Thank you received: 2098
Perhaps of interest --woodsy wrote: Sorry if i havn't searched enough but i have searched and cant find the exact info i want.
www.z1enterprises.com/ItemDetails.aspx?i...llow%29&item=DYDW500
A splicer may be an option for attaching new wires to a stock coil:
www.z1enterprises.com/ItemDetails.aspx?i...licer&item=TU38-1024
Would suggest replacing the old stock ignition coils with new Dyna green 3 ohm coils.
www.z1enterprises.com/ItemDetails.aspx?i...9+DC1-1&item=DYDC1-1
- MFolks
- Thank you received: 540
Ignition Coils And Sparkplug Wire Choices
What came with the bike, were ignition coils that even when new were marginal, add years of cooking under the tank in the stop and go traffic, and the coils will probably fail when hot.
Replacement coils can be bought at www.z1enterprises.com I believe “Emgo” is the brand. They also carry the popular Dyna 2.2 and 3 ohm coils, along with replacement sparkplug wires.
Now, you have a choice on sparkplug wires:
1.Copper plug wires with no supression caps (the best choice, but will produce audio noise on Radio’s and TV’s). Not only do the copper core wires deliver better spark, they will also deliver a much longer lifespan - carbon core wires are prone to erratic spark delivery and early breakdown, & short lifespan.
2.Copper plug wires with supression caps (a built in 5000 ohm resistor, that can sometimes fail, like what came with the bike). These should be checked with a multimeter now and then, as heat can cause them to become intermittent.
3.Copper plug wires with no supression caps, but using resistor plugs(the “R” in the plug number).
4.Supression plug wires with no supression caps.
NEVER use resistor plugs combined with supression caps along with supression plug wires, as now there will be possibly three (3) sources of resistance in the secondary windings of the ignition coils, greatly reducing the spark energy.
Another choice is the Accel 3 ohm coils, with a similar, primary(small wire)electrical connection, using ring terminals as the Dyna ignition coils do. Whatever brand of coil you go with, make sure the primary wires will clear the mounting hardware, as the spacers come close, possibly blowing a fuse. Some riders have replaced the metal spacers with non conductive Nylon spacers, reducing the chance of an electrical problem.
7mm sparkplug wires will fit the stock ignition coils(if they have replaceable wires, indicated by screw off caps on the coils with ridges). The sparkplug wires fit into a port with a brass ”Stinger” that goes into the sparkplug wire or lead(the Brit’s. Canadians, and other countries call the sparkplug wires (“High Tension Leads”).
- woodsy
can you fit carbon leads in sockets that have a screw in terminal, the coils on my kz1000 do not have sealed wires coming out but have screw in connectors eg a hole with a small screw poking up the middle to screw into the ht lead
hope that makes it clearer, cheers
- MFolks
:huh: 1979 KZ1000-B3 LTD stock coils with screw in terminals?woodsy wrote: Cheers for the replies , guys, but no one is answering the question, the question is can you fit carbon leads in sockets that have a screw in terminal, the coils on my kz1000 do not have sealed wires coming out but have screw in connectors eg a hole with a small screw poking up the middle to screw into the ht lead hope that makes it clearer, cheers
- woodsy
My bad, they have boots on but they ARE sealed in
guess i'll have to go for new coils at some point
please excuse my stupidness :woohoo:
