electrical fault finding chart???
  • steveo_4192003
  • steveo_4192003's Avatar Topic Author
  • 77kz650b-1
30 Jun 2006 00:11
#58206
i see the fault finding charts only works if you have a rectifier and regulator in a singal case!!
is there on for reg/rec seperated??
i got a kz650 b-1 i need to check out and it has them as seperate units?
thanks and have a good 4th
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
  • wiredgeorge
  • wiredgeorge's Avatar
Re: electrical fault finding chart???
30 Jun 2006 12:35
#58315
To test the regulator with the bike running, measure voltage at the battery at idle. Should be nominal 12VDC or a shade over. Measure at 4K rpm; should be about 14.5 VDC. If you have higher or lower, the only test that is easy to do on the regulator is to first disconnect battery then measure impedence between black and brown wires. I think if you have a good regulator, it should be 1050 ohms or thereabouts.
To test the rectifier bridge, there are four terminals. With the battery disconnected, put your probes on two of them. Should a lower impedence... 10 Ohms comes to mind. Reverse your probes and you should have infinite resistance I think. If you flunk after testing more than two of the checks, the rectifier bridge is bad. I am thinking this is correct as I am doing this from memory... I would definitely look at a manual to check the rectifier. I have never seen one go bad... I have seen the regulator go bad.
  • steveo_4192003
  • 77kz650b-1
01 Jul 2006 09:02
#58500
thank you wg!!
im really greatful for all your help and hope to have more advice in future!!
steve
