All 4 going at once.
  • stevie g
  • stevie g's Avatar Topic Author
10 Apr 2013 11:28 - 10 Apr 2013 11:39
#581598
Hey Guys, I cannot suss this problem so I hope one of you guys can. OK when I switch on the left turn signals it works as it should, when I turn on the right they come on but, the left turn signals also comes on including the pilot light but very dimly. As far as I can see all my wiring is correct so what can it be ? any ideas guys ? thanks $tevie. kawasaki kz1000 CSR M1
stephen g mackay
Last edit: 10 Apr 2013 11:39 by stevie g.
  • 821000ltd
  • 821000ltd's Avatar
Re: All 4 going at once.
10 Apr 2013 14:45
#581641
Check for a bad ground on the right side front and rear signal light.
82 KZ1000 LTD
Kerker 4 to 1
80 KZ 250
The following user(s) said Thank You: stevie g
  • MFolks
  • MFolks's Avatar
10 Apr 2013 15:26
#581648
Tried all new bulbs? I've seen a broken filiment touch the other one(in a dual filiment bulb),causing some strange electrical problems.
  • stevie g
10 Apr 2013 15:54
#581654
a friend of mine mentioned this (bad earth) today. OK thanks I'll give that a try tomorrow as the sun is going down here now and the bike is outside. All new turn signals though not OEM just these mini kawa lookalike from China that'll probably last a week or two. Thanks guys. I'll keep you posted, fingers crossed, cheers, $tevie.
stephen g mackay
  • baldy110
  • baldy110's Avatar
10 Apr 2013 18:19
#581678
Anytime your electrical system starts to act weird, turn on a switch and something lights up that is not supposes to, it's usually going to be a bad ground. Check your grounds.
  • stevie g
11 Apr 2013 12:19
#581802
Update:
I put an earth wire direct from the suspect indicator to the frame and all good now, thanks again to everyone for your help, Yeeha, cheers $tevie
stephen g mackay
