how do you test coil and dyna ignition on 78 b2
  • dkoz
  • dkoz's Avatar Topic Author
08 Apr 2013 11:02
#581177
hello I cant seem to be able to get a proper reading on my multi meter while trying to check ohms on the coils....??bike has a dyna electronic ignition would aney one know how to check that?? thanks for any help
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
Re: how do you test coil and dyna ignition on 78 b2
08 Apr 2013 12:54
#581189
dkoz wrote: hello I cant seem to be able to get a proper reading on my multi meter while trying to check ohms on the coils....??bike has a dyna electronic ignition would aney one know how to check that?? thanks for any help
Hello, dkoz, and WELCOME to KZrider! :cheer:
This illustration shows ohmmeter connections for measuring ohms (resistance) through an ignition coil's primary winding.
While measuring ohms, the coil should NOT be receiving any voltage.
Good Fortune! :)
The following user(s) said Thank You: dkoz
  • MFolks
  • MFolks's Avatar
08 Apr 2013 14:39
#581205
Primary(small wires) side of the coils will read between 1.8 to 3.0 ohms(some earlier Kawasaki's had coils that measured up to 4 ohms or more).
Secondary(sparkplug wire ports)side of the coil will read between 10.4K to 15.6K ohms. These ports are wired together.
  • bountyhunter
  • bountyhunter's Avatar
08 Apr 2013 16:16
#581217
You can't check a coil properly with a multimeter. A failing coil will get arcing from the high voltage side to low voltage side. You don't have the equipment to check for that. many bad coils only start "breaking down" when they get hot.
  • dkoz
08 Apr 2013 21:00
#581256
Thanks for the help....i was testing the right wire's! But batery was still connected..
Checked again meter was reading same way jumping from 0.06 to 16. Whatever.. too 1..or zero..
Meter must be fuzzed up..
That being said after a quick plug boot repair..plenty of pretty blue spark with plug in boot laying up against block.
Took bowels off and found filth setting in bottom of them..air bleed tubes cloged 8 out of 12 holes blocked .
Surprisingly pilot's wear cleen..
Thanks for the people who gave me thear time. This is a cool site will learn alot here i know.. :)
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
  • Old Man Rock
  • Old Man Rock's Avatar
08 Apr 2013 23:48 - 09 Apr 2013 10:02
#581312
Attachment DynaSBenchTest.JPG not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 09 Apr 2013 10:02 by Old Man Rock.
