Replaced Battery, Turn Signals Not Working
- snowjoe23
04 Apr 2013 06:00
I just replaced my battery tonight. Went to fire up my bike. At first it tried to start and then cut out all of a sudden. Couldn't get it to turn over. Disconnected the battery, reconnected it and it started right up but the blinkers won't work. They won't even light. Any ideas? I checked the fuse box and all three fuses seemed fine. Any help would be greatly appreciated.
Re: Replaced Battery, Turn Signals Not Working
04 Apr 2013 09:08
If not already done, would verify integrity of the ground connection where the negative battery cable attaches to the rear of the engine.
- 4TheKZ1000
04 Apr 2013 10:18Patton wrote: If not already done, would verify integrity of the ground connection where the negative battery cable attaches to the rear of the engine.
This is 1000% correct....just happened to me and it sucked. I chased my tail around for quite a while......:ohmy:
Check batt post
Battery cable
Wire harness gound pigtail from negitive battery led and connections....this is where I had a problem.
It you check your turn signal wires for 12volt and you have 12volts there....you have a main ground fault. I was getting 12 volts to all my stuff but they wouldnt fuction....
- turboking
04 Apr 2013 10:34
:blink: sounds like a bad ground
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- slayer61
- KZR FLAG RELAY CARRIER #62
04 Apr 2013 11:37
Fuses "seemed fine"! What does that mean? Fuses are good- or fuses aren't good. Kind of like being pregnant... you are, or you aren't. "she didn't SEEM pregnant"!
- snowjoe23
04 Apr 2013 16:21
The cable looks solid from the post to the ground. Ground looks good, no rust. I have an update relay with LEDs on front, originals on back. The hazards on all for lights work just fine, but no blinkers at all. What do you mean by "wire harness ground pigtail"?
And can anybody tell me what the small black wire coming from the left side of the bike (just to the left of the fuse box) running over to the battery is for?
[attachment:2]C:\fakepath\wire.JPG[/attachment]
- Topper
04 Apr 2013 17:18
Your pic didn't make it. Give it another shot.
When I upgraded to LED bulbs I had to get a no load flasher unit. That unit had a little wire on it that wasn't on the OEM flasher. It needed to be connected to ground for the blinkers to blink. Maybe yours came loose?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- snowjoe23
04 Apr 2013 20:39
No, it's not my relay ground either. That's well grounded and connected. Let me try the pic again
www.flickr.com/photos/jamesloganphotogra...es/k/in/photostream/
- snowjoe23
31 May 2013 17:40
Okay, it's worse than I thought. My battery is not charging now. My head and tail lights still work, but they drain the battery... ugh. Any thoughts what might be causing this? Did I somehow blow my regulator? Something else?
31 May 2013 18:03
Please add your bike's year & model to your signature line. Different KZ models have different charging systems. Ed
