KZ700 Coils
  • Marklorenzo
  • Marklorenzo's Avatar Topic Author
KZ700 Coils
31 Mar 2013 23:03
#579863
Hello everyone.
My kz700 had a bit of a problem yesterday on its first ride. Basically caught the underside of gas tank and breather hose on fire. A plug wire off of coil must of came loose while putting fas tank back on. Burnt my coil up. I need to buy new coils but not sure what OHM to get. On the bike currently is andrews products 1287. I can not find any information on these coils. If someone could direct me the right way. I tried to get a resistance reading off of coils but couldn't find anything. Thanks
1984 KZ700 A1
  • MFolks
  • MFolks's Avatar
Re: KZ700 Coils
31 Mar 2013 23:25
#579868
Most motorcycle coils are between 1.8 to 3 ohms, some older Kawasaki's had 4 ohm coils, but those had a ballast resistor. I'd imagine a new, 3 ohm coil will work for your bike, but replace both at the same time.
  • Marklorenzo
Re: KZ700 Coils
31 Mar 2013 23:47
#579873
I have looked at the dyna 3.0 coils dual output coils. But they look like they won't fit properly under my gas tank.
1984 KZ700 A1
  • MFolks
  • MFolks's Avatar
Re: KZ700 Coils
01 Apr 2013 00:49
#579878
You'll probably need to fabricate some custom mounting brackets to use either the Dyna or Accel 3 ohm coils. Read this: www.kzrider.com/forum/4-electrical/55555...ng-dyna-coils#555956
Make sure the sparkplug wires will clear the tank, as some riders have had vibration rub through the insulation, making the engine erratic in operation.
  • loudhvx
  • loudhvx's Avatar
Re: KZ700 Coils
01 Apr 2013 03:38 - 01 Apr 2013 03:40
#579892
The Accel 3 ohm coils will probably work (as Mfolks mentioned) if you have the stock ignition, and they fit similarly to the Blue Andrews coils, if that's what you have now.
If you get Dyna Gray 2.2 ohm coils, they are a better match for the stock igntion, but might be harder to fit depending on the mounts.
Last edit: 01 Apr 2013 03:40 by loudhvx.
  • Marklorenzo
Re: KZ700 Coils
01 Apr 2013 07:04
#579902
I have the yellow andrew coils currently.
1984 KZ700 A1
  • martin_csr
  • martin_csr's Avatar
Re: KZ700 Coils
01 Apr 2013 10:11
#579915
Marklorenzo wrote: I have looked at the dyna 3.0 coils dual output coils. But they look like they won't fit properly under my gas tank.
You could fab up some mounting brackets. Some guys used L-brackets from the hardware store.
I don't have a photo, but here's a topic w pics. KZR - mounting Dyna coils
  • Marklorenzo
Re: KZ700 Coils
01 Apr 2013 10:58
#579922
I just ordered the dyna coils. Going to make L brackets to make them work. Thanks!!!
1984 KZ700 A1
