Dyna S Ignition
- Landfair
Dyna S Ignition
26 Mar 2013 14:38
Hey I had heard this was a must have for these kz bikes to do away with the points. Is any electronic ignition system good for it or is the dyna specifically a must have? Any input is greatly appreciated and if you have one fairly cheap let me know.
06 Ninja 650r
76 kz900 motor and parts 80 kz1000 frame (project)
Ktm 520 supermoto
01 katana (for sale)
Ktm 520 supermoto
- 4TheKZ1000
Re: Dyna S Ignition
26 Mar 2013 14:55 - 26 Mar 2013 15:22
I am Dyna-S 100% and wouldnt run points. I like set the timming and forget of the Dyna-S with no maintance.
I really cant speak of points on a KZ as my bike was purchased with a Dyna-S. 650ed is a good source to ask about points. He runs them with good results and likes them.
There are good a bad things with both a Points ign and Dyna-S ign.
The Dyna-S can cost some money. You need 3.0 ohm coils to go with the Electronic module.
I would listen to the forum feedback and make your own call.
Last edit: 26 Mar 2013 15:22 by 4TheKZ1000.
- MFolks
Re: Dyna S Ignition
26 Mar 2013 18:49
Do not use the supplied "Splice" that comes with the Dyna S for the power, as it's not a very good electrical connection, instead, use solder and heatshrink tubing for a water resistant joint.
The following user(s) said Thank You: Landfair
- Landfair
Re: Dyna S Ignition
26 Mar 2013 19:24
4TheKZ1000 so I cannot use my old coils i need new to run a dyna s? Thats starting to sound expensive :ohmy:
06 Ninja 650r
Ktm 520 supermoto
Ktm 520 supermoto
- Powerstroke_fan
Re: Dyna S Ignition
26 Mar 2013 19:33
You shouldnt use oem coils. But you can run other than 3 ohm i believe. Theres diffrent brand coils you can run, accel, dyna and theres another but cant think of it.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- MFolks
Re: Dyna S Ignition
26 Mar 2013 20:40
- loudhvx
Re: Dyna S Ignition
26 Mar 2013 22:38
If your original coils are for points, and the coils are good, then they will work fine with the Dyna S.
If your original coils are for the Kawasaki electronic ignition, then you will need new 3-ohm, or higher, coils.
If your bike came with electronic ignition from the factory, that is a better system than the DYna S when working properly.
You should put your bike in your signature so we know what you have.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Landfair
Re: Dyna S Ignition
26 Mar 2013 22:55
I have a 76 kz900 motor (as far as i know) I am in college and work on the bike off and on buy parts at school work on it when im home and I got the bike it a few totes so im not sure if it does with out checking. I just ass u me d that it had points.
06 Ninja 650r
Ktm 520 supermoto
Ktm 520 supermoto
- MFolks
Re: Dyna S Ignition
26 Mar 2013 23:05
If you remove the right side engine cover(it's about CD in size), this is where the ignition points would be, on later bikes, the pulsing(pick up coils) were there for the electronic igniton and mechanical ignition advancer. If posible, take some pictures of what you've got.
- Landfair
Re: Dyna S Ignition
26 Mar 2013 23:16
Yeah ill check next time im home
06 Ninja 650r
Ktm 520 supermoto
Ktm 520 supermoto
