ODYSSEY PC310 for a KZ 1000
  • kzz1king
  • kzz1king's Avatar Topic Author
25 Mar 2013 23:24 - 25 Mar 2013 23:24
#578788
What do you think of the specs? Work ok for a stock motor? Room is at a premium and this will fit my build nicely. Not so nicely if it won't do the job.
www.odysseybatteries.com/battery/pc310.htm
310 cranking amps for 5 seconds
250 cranking amps for 10 seconds
225 cranking amps for 20 seconds
200 cranking amps for 30 seconds
8 Ah
Short circuit current over 455A
9 minute reserve capacity with 25amp load
CCA - 100 (Is this important?)
Length 5.43"
Width 3.39"
Height 3.98"
Weighs 5.9 lbs
Home built KZ1000 turbo setup
Last edit: 25 Mar 2013 23:24 by kzz1king.
  • MFolks
  • MFolks's Avatar
Re: ODYSSEY PC310 for a KZ 1000
26 Mar 2013 00:16
#578795
  • kzz1king
26 Mar 2013 13:04
#578882
Thanks , the ballistic batteries give more info and give a range of what displacement/type motor the battery will work with which is more suitable for me finding what I need for my application. Looks like this one would do the job: www.pegasusautoracing.com/productdetails.asp?RecID=9403
Anyone useing Ballistic products?
Wayne
