Dyno connectors
  • Haybus
  • Haybus's Avatar Topic Author
  • Big Al
Dyno connectors
22 Mar 2013 21:42
#578224
Does anybody know of a source for these connectors? I'm talking about the ones that are crimped and push into the 6 pin connector (3 for dyno, 1 oil pressure, 1 neutral indicator, 1 empty). They have the wings that keep them in the plastic shell. All my plastic shells are in really good shape. Would like to reuse the plastic and just crimp on new pins on new wire. Looked at RIWire, Vintage Connections and Mouser and didn't see what I need. Mouser has some stuff that's close, but not the same. Course they have tons of stuff so maybe I'm just missing it.
Attachment DSCF2036.JPG not found
2nd, a source for the push on round connectors for the oil pressure and neutral indicator posts? They're not threaded so a ring terminal won't cut it. Could probably reuse the bare bent up terminal in the picture, but no way on the molded one.
Attachment DSCF2037.JPG not found
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Dyno connectors
22 Mar 2013 22:00
#578227
Re: Dyno connectors
22 Mar 2013 22:44
#578233
Here are a couple sources for various connectors. They may have what you need. Ed
www.hvccycle.com/electrical-connectors.html
vintageconnections.com/
  • Haybus
  • Big Al
Re: Dyno connectors
22 Mar 2013 23:05
#578237
2005 FJR
2009 Hayabusa
  • MFolks
  • MFolks's Avatar
  • Haybus
  • Big Al
Re: Dyno connectors
23 Mar 2013 00:06
#578248
Those are a bunch of excellent links. Thanks a bunch.
2005 FJR
2009 Hayabusa
Re: Dyno connectors
23 Mar 2013 04:38
#578274
If not already done, would also take a look at
www.z1enterprises.com/ShopByCategory.asp...category=0102010304#
Good Fortune! :)
  • Haybus
  • Big Al
Re: Dyno connectors
23 Mar 2013 11:19
#578312
Z1E only has the flat style in their catalog.
2005 FJR
2009 Hayabusa
  • pig9r
  • pig9r's Avatar
Re: Dyno connectors
23 Mar 2013 12:14
#578317
Eastern beaver link in mfolks post has the connector pins.
