Kz1000 Lithium Battery?
  • KzChop82
  • KzChop82's Avatar Topic Author
19 Mar 2013 13:59
#577694
Is there anyone out there using a lithium ion battery for a kz?
What level of crank amps would I need to be on the very safe side?
Any thoughts would be greatly appreciated.
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
  • baldy110
  • baldy110's Avatar
Re: Kz1000 Lithium Battery?
19 Mar 2013 14:12
#577696
I am using the ballistic performance 8 cell battery. It puts out 210 amps and spins my modded 1135cc engine very quickly. It sure is small and whole lot lighter. I did have to use the packing foam it came with to fill in the battery box to get it to fit snug. I also had to make a restraining strap to keep the battery in place due it's small size. I am very happy with it though. it does not require a battery tender when I let the bike sit. It keeps it's charge for months. Last year the bike sat for 3 months and fired right up like a new battery. The only down side is the cost, about $150.00.
  • MFolks
  • MFolks's Avatar
  • bountyhunter
  • bountyhunter's Avatar
19 Mar 2013 15:59 - 19 Mar 2013 17:12
#577716
I just priced the Shorai Li batteries for my KZ 750 and they were $144 at Misha cycle place. They had best prices and free shipping.
mishacycles.com/store/Batteries/
Last edit: 19 Mar 2013 17:12 by bountyhunter.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
19 Mar 2013 17:34
#577720
im using a dry core autozone batt on a high compression motor and it spins it super fast....its like 220 CCA. $85.00
  • Hollywoodmx
  • Hollywoodmx's Avatar
19 Mar 2013 23:07
#577767
baldy110 wrote: I am using the ballistic performance 8 cell battery. It puts out 210 amps and spins my modded 1135cc engine very quickly. It sure is small and whole lot lighter. I did have to use the packing foam it came with to fill in the battery box to get it to fit snug. I also had to make a restraining strap to keep the battery in place due it's small size. I am very happy with it though. it does not require a battery tender when I let the bike sit. It keeps it's charge for months. Last year the bike sat for 3 months and fired right up like a new battery. The only down side is the cost, about $150.00.
I have the anti gravity 12 cell for my yamaha vtwin which requires A LOT more cca to turn. Its a little bigger than my fist. I did the research on them and antigravity had better reviews than the others.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • steell
  • steell's Avatar
20 Mar 2013 00:00 - 20 Mar 2013 00:02
#577777
I use an 8 cell lifePo battery on my 750 twin. Spins it over faster than a brand new lead acid battery did. On the ZX12 I use an 8 cell and a 4 cell so I can have 24 volt start.
Last edit: 20 Mar 2013 00:02 by steell.
  • Hollywoodmx
20 Mar 2013 03:35
#577798
steell wrote: I use an 8 cell lifePo battery on my 750 twin. Spins it over faster than a brand new lead acid battery did. On the ZX12 I use an 8 cell and a 4 cell so I can have 24 volt start.
In series?? Do the cca's combine as well?
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
