kz900 wiring harness
- chevyboy
12 Mar 2013 17:08
i know that most of the kz bikes were very very similar engine and design wise. but does anyone know if you can use any other wiring harnesses? say off of like a kz750 or 650 to wire up a 900? im in the middle of a complete rebuild and i have no wiring harness
- mick z1a
Re: kz900 wiring harness
12 Mar 2013 19:00
No eBay APP ID and/or Cert ID defined in Kunena configurationthese chaps will send to north USA, odd really, all their stuff comes from the USA
12 Mar 2013 19:12chevyboy wrote: i know that most of the kz bikes were very very similar engine and design wise. but does anyone know if you can use any other wiring harnesses? say off of like a kz750 or 650 to wire up a 900? im in the middle of a complete rebuild and i have no wiring harness
Not really. The KZ line included everything under the sun starting with a 1 cylinder air cooled KZ200 all the way up to a 6 cylinder water cooled KZ1300 and everything else in between. Ed
- Kawickrice
12 Mar 2013 19:15
You can get a new harness from Z1 Enterprises and the cost is very reasonable.
To answer your question, yes the harnesses from different KZ's are similar but not exact. The connectors are the same generally. I did my 900 years ago with a KZ 440 harness, most was plug and play except the harness was a lot shorter from front to rear. I made up the difference with a custom plug extension. The other issue I had was the charging system. I also had to add another coil wire as the 440 uses a single coil. Every thing else was color correct and the connectors were the same and the wire colors were same. I did this years ago and have had zero harness related problems. It takes some time and patience but what doesn't. Just get schematics from your bike and the donor bike and attack one circuit at a time. Good luck on which ever direction you take.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
