Electrical Problem ****SOLVED****
- 4TheKZ1000
10 Mar 2013 14:01 - 10 Mar 2013 21:25
Bike was fine all winter. Tail light worked, turn signals worked, brake lights and it cranked great. Went though and improved wiring and trouble shooted it ready for good weather.
Went to start bike today and it started and I let it idle for a few and it quit running.
I went to restart bike and noticed that the headlight didnt come on with key? I hit start button and it didnt crank?
I checked the fuses and they were all good not blown....I then checked the battery ground, white ign wires and just went over wiring harness without finding fault.
So I have no power comming back to controls....no headlight, turn sigs, brake lights, horn...When I turn key on the neutral light is bright....I hear the relay for coils click on....Im thinking ignition switch first then starter relay? What do you guys think.
Thanks, Spencer
Thanks, Spencer
Last edit: 10 Mar 2013 21:25 by 4TheKZ1000.
- wireman
Re: Electrical Problem Help Needed..
10 Mar 2013 14:07
What else did you do to wiring besides that cursed coil mod?
Attachment omrcursesfoiledagain2_2013-03-10.jpg not found
- 4TheKZ1000
10 Mar 2013 14:39 - 10 Mar 2013 14:54
Have power at main fuse
Have power at coils
Have power going to ign switch.
ck ground and is good
Have power at coils
Last edit: 10 Mar 2013 14:54 by 4TheKZ1000.
- wireman
10 Mar 2013 15:09
Power to starter solenoid? Do you have a clutch lever/starter lock out switch?
Try bumping across the contacts on solenoid,just make sure its in neutral first! :laugh:
- 4TheKZ1000
10 Mar 2013 15:22 - 10 Mar 2013 15:30
No lock out on clutch
I have power comming into ign switch through 2 wires
When ign switch is turned on I have power going out of ign switch to all wires.
When the ign switch is turned on. The two out of three connections to the head light are showing power but light dosent work. I tried the old one that worked before changing and it didnt work...I havent cked the volts/amps yet....will do that.
I hooked up my batt charger and hit the boost and didnt help.
I have 12.25 volts at the ign switch
I have 11.75 volts at the headlight pigtail but light wont work.
I am confused????
I am confused????
Last edit: 10 Mar 2013 15:30 by 4TheKZ1000.
- wireman
10 Mar 2013 15:31
Don't use the boost on your charger with a motorcycle battery,check actual voltage to starter solenoid.
- 4TheKZ1000
10 Mar 2013 15:53wireman wrote: Don't use the boost on your charger with a motorcycle battery,check actual voltage to starter solenoid.
12.3 volts at postive post start solenoid
- wireman
10 Mar 2013 16:05
At the battery cable or the wire coming from ignition?
- 4TheKZ1000
10 Mar 2013 16:12 - 10 Mar 2013 16:13wireman wrote: At the battery cable or the wire coming from ignition?
ckd the batt only at 12.70
ckd 20amp fuse 12.70
ckd 2 hot wires going to ign switch and all comming from ign switch in on position.....11.3 to 12.0 no dead wire from ign.
Last edit: 10 Mar 2013 16:13 by 4TheKZ1000.
- wireman
10 Mar 2013 16:16
Allright check the voltage at cable for starter when pushing starter button
- 4TheKZ1000
10 Mar 2013 16:20wireman wrote: Allright check the voltage at cable for starter when pushing starter button
Nothing....
- wireman
10 Mar 2013 16:25
Sounds like you have a flat solenoid,you could jump between the 2 big cables battery/starter just to make sure though.
