IC IGNITER ?
- loudhvx
Re: IC IGNITER ?
06 Aug 2006 22:33
Slammed,
The Dyna III replaces the pickup, rotor (on the mechanical advancer), and ignitor. The DYna III requires the ignition coils to be 3-ohms or higher otherwise the life of the Dyna may be shortened.
The stock coils, for KZ's with electronic ignition, are 2.5 ohms. If the 1981 650 CSR had points, then the stock coils should be 4-ohms.
Post edited by: loudhvx, at: 2006/08/07 01:37
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Slammed
Re: IC IGNITER ?
07 Aug 2006 03:21
Thanks for the reply I am guessing after doing some reading that the 81 did not have points it came with electronic ignition now I just need to find out why I dont have any spark
P.s anybody know where this wire goes??
loudhvx wrote:
Post edited by: Slammed, at: 2006/08/07 06:22
loudhvx wrote:
Slammed,
The stock coils, for KZ's with electronic ignition, are 2.5 ohms. If the 1981 650 CSR had points, then the stock coils should be 4-ohms.<br><br>Post edited by: loudhvx, at: 2006/08/07 01:37
- Slammed
Re: IC IGNITER ?
07 Aug 2006 03:27
Oops forgot the picture
Post edited by: Slammed, at: 2006/08/07 06:28
- Slammed
- loudhvx
Re: IC IGNITER ?
07 Aug 2006 08:47
I believe that wire is for add-ons. I don't think it should be connected to anything.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Slammed
