IC IGNITER ?
- mecyclebum
I tried searching on the web but found little information on this.
Pollock
Post edited by: mecyclebum, at: 2006/06/27 22:47
- steell
This pic is of the 82 GPz750 ignition, if there is any difference in advance it will be in the timing advancer (the round thing at lower left).
Post edited by: steell, at: 2006/06/27 23:08
- loudhvx
- Thank you received: 1615
Post edited by: loudhvx, at: 2006/06/28 12:30
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- steell
If your friends GPz750 was a monoshock then it's an 83, the 82 was still twin shock.
buykawasaki.com is often wrong though, as am I
Post edited by: steell, at: 2006/06/28 12:40
- loudhvx
83 was the first year for the electronic advance on the 750's as far as I know.
buykawasaki.com is often wrong though, as am I <br><br>Post edited by: steell, at: 2006/06/28 12:40
Yeah, it was monoshock. More likely my friend was wrong on what year it was.
1981 KZ550 D1 gpz.
Other links.
- mecyclebum
BTW I spent time researching the correct ignitor to go on my 1982 KZ750H but it probably doesn't make any difference. The firing order on all 4's are the same I am guessing. Correct or am I missing something?
Pollock
steell wrote:
The ignitor is not going to have anything to do with the advance curves since those bikes have mechanical advancers.
<br><br>Post edited by: steell, at: 2006/06/27 23:08
- loudhvx
Okay, thanks. I am new to this electronic ignition on bikes. All my other bikes have magnetos. I am guessing the ignitor (Capacitors I am guessing) and coil are separate whereas in a electronic ignition in cars they are one unit called coil pack...which act as capacitor and coils. I read the manual It either went over my head or the Haynes didn't explain it that well.
Pollock
steell wrote:The ignitor is not going to have anything to do with the advance curves since those bikes have mechanical advancers.
The firing order is the same on all four cylinder KZ's (and probably all inline fours that use two dual-coils).
The ignitor is a transistor along with a few other components which does away with the need for a capacitor. It is not a CDI, by the way, it is a transistorized ignition. (CDI is capacitive discharge which is used on some older Kaws, but not on KZ's.)
1981 KZ550 D1 gpz.
Other links.
- trippivot
- Thank you received: 3
different vendor source of the guts T.P.I transistorized pointless Ignition (yamaha says T.C.I)
almost forgot higher RPM allowed too
Post edited by: trippivot, at: 2006/06/29 10:15
- Slammed
- steell
- Slammed
steell wrote:
You have two wires in one sleeve coming out of the bottom of the small round cover on the right lower side of the motor. Follow those two wires till they enter a box and you have found the igniter. Probably a plug connecting those two wires to the ones going into the box. Should be two sets of wires going into that box, both ending in plugs.
- Slammed
