Need 250 igniter info
- skitch
31 Oct 2005 18:24
Yeah, it's the same questions I was asking 6 months ago when I was here. I have an '83 KZ250 motor with no wire harness and no diagrams. I need to wire in the igniter. It has five prongs, it's the electronic advance. Which prong goes to what?
Post edited by: skitch, at: 2005/11/02 17:02
- zedheadmc
Re: Need 250 info
31 Oct 2005 21:20
Get me a fax number and I'll send you a copy of the wiring diagram.
- skitch
Re: Still Need 250 info
01 Nov 2005 06:41
I don't have a fax. Can you scan that portion and email or post it?
That's the only part I need. I have completed the rest of the wiring without needing a diagram.
The captions' not quite right- it's an '83
Here's my dilema,
Post edited by: skitch, at: 2005/11/02 00:02
Post edited by: skitch, at: 2005/11/02 17:03
Post edited by: skitch, at: 2005/11/03 20:49
Here's my dilema,
- skitch
01 Nov 2005 21:07
I don't even need a diagram so much; If someone printed my pic and wrote in the details, you could mail it to me!
- zedheadmc
01 Nov 2005 22:22
I found the Z250/Z305 manual at work, but I forgot to bring it home. I will remember to bring it home tomorrow.
- zedheadmc
02 Nov 2005 21:55
O.K. heres the deal. I have a factory manual # 99924-1019-04 and it only goes up to 1982 (which is a points ignition). Let me check one more time for something covering 1983. I do apologize, I thought I had it covered.
- zedheadmc
03 Nov 2005 16:54
Using factory manual #99924-1023-04 (page 237 1981 supplement chapter) this is what I've come up with.
And using your caption, top row, left to right #1=coil, #2=ground, #3=pickup(-)
Bottom row, left to right #1=battery and #2=pickup(+)
Hope this is right and helps.
- skitch
03 Nov 2005 17:43
Looks like a good start. I'll let you know when it's running. To be sure I understood, is this what you mean?
Thanks a lot!
Post edited by: skitch, at: 2005/11/03 20:48
Thanks a lot!
- zedheadmc
04 Nov 2005 06:43
That is correct sir, or at least thats the way I read it in the manual. Good luck and keep us posted.
