mounting dyna coils
  • ironleg
  • ironleg's Avatar Topic Author
  • its not what you ride its why
mounting dyna coils
01 Mar 2013 16:11
#574755
i have done a search on here and got some use full info thanks ! my ? is anyone ever put them on the front of the frame in front of the horn just below the steering stem ?? i have them that way on my drag bike thay work well ther but it never gets rode in the rain ! the reson im asking is i have a 78 ltd 1000 and have done some frame work like rake the front and add gusits well not lookin ahead now i dont have the room to mount the bigger dyna coils in the stock place ! any thoughts ?
78 1000 ltd current project
75 z1 900 Dragbike 78 frame GS 1100 swing arm yamaha rear wheel dyna-s dyna 2 step best time 12.02 1.59 60ft
71 harley shovelhead chopper
2002 harley springer softail
1999 yamaha 600 grizzly
  • MFolks
  • MFolks's Avatar
Re: mounting dyna coils
01 Mar 2013 16:18
#574757
It might help in cooling the ignition coils, but would also expose them to vibration(unless you can rubber or vibration isolate them. The slightly longer sparkplug wires would need additional insulation(maybe a spiral wrap) to prevent rubbing through on the frame parts & spark loss.
How are you going to prevent the sparkplug wires from flexing during a ride? If you tie them to the frame, I see potential problems.
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
01 Mar 2013 16:36
#574759
I have seen this installation done in my youth (MANY years ago) on Yamaha RDs and the like... 1st thought was, it would keep the coils cool, but it blocks air to the cylinders and they might run a litle warmer. just my .02 Paul
  • ramtough_63
  • ramtough_63's Avatar
01 Mar 2013 16:39
#574760
I relocated my coils on my gold wing it does fine in the rain but if i hose it down they get wet and it acts up til they dry out
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • martin_csr
  • martin_csr's Avatar
01 Mar 2013 18:51 - 01 Mar 2013 19:23
#574776
At the primary leads, you could use some clear RTV sealant or something - I thought that suggestion was in the Dynatek literature somewhere. Solder the ring terminals to the wires & use some heat shrink tubing, then add the sealant to the finished connection to make it water proof. The spark plug wires have the rubber boots, so hopefully those are good in the rain.
Last edit: 01 Mar 2013 19:23 by martin_csr.
  • ironleg
04 Mar 2013 01:03
#575202
thank you for the input !! i wouldnt think ther would be anymore vibration then if you had them in the stock place. and as far as the weather and water proofing i would do that even if thay was going under the tank. as for the engine heat im goin to place them in front of the horn . i will get the on and try to post up some pics
thanks agin for all the input !!
