stupid question about mounting dyna coils
  • richrand
  • richrand's Avatar Topic Author
25 Feb 2013 22:41
#574150
I can't really stop thinking about this so here goes: I mounted them so the wires point toward the rear. It's a tight fit and the rearmost wires press against the frame but it works . Is there any reason to not mount them like this?
  • 0Z.Z1R Mk2
  • 0Z.Z1R Mk2's Avatar
Re: stupid question about mounting dyna coils
26 Feb 2013 00:08 - 26 Feb 2013 00:09
#574162
It doesn't matter which way you mount them...as long as your happy. ;)
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
Last edit: 26 Feb 2013 00:09 by 0Z.Z1R Mk2.
  • MFolks
  • MFolks's Avatar
26 Feb 2013 00:22
#574169
Avoid if possible, place where the spark energy can jump to ground, like the underside of the tank,or the frame. Perhaps some spiral wrap around the sparkplug wires will prevent rubbing through the insulation. Radio Shack sells 1/4" I.D. spiral wrap that works well for rub protection on brake lines too.
  • donthaveakawman
  • donthaveakawman's Avatar
26 Feb 2013 01:32
#574205
coils put out ac voltage, sounds dangerous.
  • trianglelaguna
  • trianglelaguna's Avatar
26 Feb 2013 01:39
#574209
they really only fit one way decent enough to wire em up...cant remember right now which way... but you must have em right ...and either way they are super cramped...watch for sure that the wires to the ignition and the plug wires are not able to contact anything..tape...silicone...cover the screws..
MFolks wrote: Avoid if possible, place where the spark energy can jump to ground, like the underside of the tank,or the frame. Perhaps some spiral wrap around the sparkplug wires will prevent rubbing through the insulation. Radio Shack sells 1/4" I.D. spiral wrap that works well for rub protection on brake lines too.
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
26 Feb 2013 02:08 - 26 Feb 2013 02:11
#574220
richrand wrote: I can't really stop thinking about this so here goes: I mounted them so the wires point toward the rear. It's a tight fit and the rearmost wires press against the frame but it works . Is there any reason to not mount them like this?
Per Dyna Instructions:
NOTE: Honda and Suzuki mounting uses the two holes that are farthest apart; with the secondary towers pointing down and back on Honda's, and down and forward on Suzuki's. Kawasaki mounting uses the two holes nearest the coil body. The secondary towers will point up and forward on KZ900/KZ1000's and down and
forward on KZ650's.
See > www.timscbx.com/PDF%20docs/SPK119Install.pdf
Good Fortune! :)
Last edit: 26 Feb 2013 02:11 by Patton.
  • martin_csr
  • martin_csr's Avatar
26 Feb 2013 10:52 - 26 Feb 2013 11:56
#574246
I don't know about your bike, but on the 81 KZ650 the Dynas can't be mounted the same as stock. So I made a couple of mounting bracket extenders from 1-1/2" x 36 angle bar aluminum from the Home Depot (1 bracket per side). This allowed an offset from the stock mounting points, so the coils are more forward w the plug wires pointing downward towards the rear.
I did them similar to these topics but offset forwards & tucked closer to the frame.
www.kzrider.com/forum/5-chassis/468395-dyna-coil-mounting-help
www.kzrider.com/forum/4-electrical/55555...ls-to-a-750-4#555561
Last edit: 26 Feb 2013 11:56 by martin_csr.
  • Haybus
  • Haybus's Avatar
  • Big Al
22 Apr 2013 22:33
#583620
Do the coils need the mounting isolated from the frame, connected to frame ground or doesn't matter? I have the green 3ohm Dyna coils, mounted with new brackets to clear the frame/tank on a newly powder coated frame and I'm wondering, were they grounded through the frame before? Sorry if that's a dumb question.
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
  • MFolks
  • MFolks's Avatar
22 Apr 2013 23:24
#583628
No, the coils could even be insulated, as it makes very little difference if they are grounded or not.They are similar to flyback transformers,boosting a voltage up, so it jumps a gap(sparkplugs).
The following user(s) said Thank You: bluezbike, Haybus
  • NZGlenn
  • NZGlenn's Avatar
24 Apr 2013 05:24
#583804
Just put Dyna coils on my GPz1100
I adjusted (bent) the standard brackets down so that the wires cleared the frame and tank
See left original right Dyna
Attachment 23032013603.jpg not found
Dyna both sides
Attachment 23032013606.jpg not found
1984 GPz1100A2
