KZ1000 Ignition Coils
- MtStateMike
17 Feb 2013 13:10
While redoing the bike this winter, i removed the coils to pull the valve cover and found that one of coils has the plug wire melted inside it. So I need to replace at least one of them. I checked BikeBandit and found Coil Ignition #1 for $82.80 and Coil Ignition #2 for $129.16. I then look on ebay and found a replacement Coil Ignition for $43.40, which it says that it replaces Ignition Coil 21121, but does not say anything about the 21121A that is coil #2. Will this work for both or do I have to find another coil?
92 KZ1000p
Lumberport, WV
Lumberport, WV
- bluej58
Re: KZ1000 Ignition Coils
17 Feb 2013 14:01
I need fresh coils some day and I'm pretty sure that these are the ones for me.
www.z1enterprises.com/ItemDetails.aspx?i...9+DC1-1&item=DYDC1-1
Not sure about your 1000 though, someone will be along shortly to correct me :huh:
Z1E has a bunch for sale ( wires sold separately )
JD
JD
78 KZ1000 A2A
- baldy110
18 Feb 2013 14:25 - 18 Feb 2013 14:27
Yes those will work and you will be happy with them. On all my vintage bikes I work on I replace the stock coils with those, even if I have no problem with the stock ones. I don't trust 30 year old electronics exposed to vibration and heat.
Last edit: 18 Feb 2013 14:27 by baldy110.
- MFolks
18 Feb 2013 15:57
Even when new, the stock coils were marginal, add years of under the tank heat and vibration, and now they have become unpredicable in their use.
- wireman
18 Feb 2013 16:11
Weve been overrun by sales reps from dyna! :woohoo:
If you have access to a multi meter check the resistance on the coils like it shows in the manual,If one is questionable change them both out.
- bountyhunter
18 Feb 2013 18:19 - 18 Feb 2013 18:23
Agree that 30 year old coils need to get punted. Fastest way to kill any electronic device is heat, vibration and high voltage. The "coil" has the trifecta of early death.
I have been running this one for about five years, works great, comes with wires and only costs $36. It's a four Ohm coil but could be used in place of a three Ohm. If there is any difference in performance it will probably be microscopic.
www.z1enterprises.com/ItemDetails.aspx?i...zuki&item=EM24-72451
Last edit: 18 Feb 2013 18:23 by bountyhunter.
- MtStateMike
18 Feb 2013 22:52
Yeah, I think I am going to go ahead and order the Dyna Coils from z1. I always thought last year that my bike wasn't running the best it could. Now looking at the one coil may explain what I was feeling.
92 KZ1000p
Lumberport, WV
Lumberport, WV
- MFolks
19 Feb 2013 00:18
Ignition Coils And Sparkplug Wire Choices
What came with the bike, were ignition coils that even when new were marginal, add years of cooking under the tank in the stop and go traffic, and the coils will probably fail when hot.
Replacement coils can be bought at www.z1enterprises.com I believe “Emgo” is the brand. They also carry the popular Dyna 2.2 and 3 ohm coils, along with replacement sparkplug wires.
Now, you have a choice on sparkplug wires:
1.Copper plug wires with no supression caps (the best choice, but will produce audio noise on Radio’s and TV’s). Not only do the copper core wires deliver better spark, they will also deliver a much longer lifespan - carbon core wires are prone to erratic spark delivery and early breakdown, & short lifespan.
2.Copper plug wires with supression caps (a built in 5000 ohm resistor, that can sometimes fail, like what came with the bike). These should be checked with a multimeter now and then, as heat can cause them to become intermittent.
3.Copper plug wires with no supression caps, but using resistor plugs(the “R” in the plug number).
4.Supression plug wires with no supression caps.
NEVER use resistor plugs combined with supression caps along with supression plug wires, as now there will be possibly three (3) sources of resistance in the secondary windings of the ignition coils, greatly reducing the spark energy.
Another choice is the Accel 3 ohm coils, with a similar, primary(small wire)electrical connection, using ring terminals as the Dyna ignition coils do. Whatever brand of coil you go with, make sure the primary wires will clear the mounting hardware, as the spacers come close, possibly blowing a fuse. Some riders have replaced the metal spacers with non conductive Nylon spacers, reducing the chance of an electrical problem.
7mm sparkplug wires will fit the stock ignition coils(if they have replaceable wires, indicated by screw off caps on the coils with ridges). The sparkplug wires fit into a port with a brass ”Stinger” that goes into the sparkplug wire or lead(the Brit’s. Canadians, and other countries call the sparkplug wires (“High Tension Leads”).
