Opinions on a new starter motor...
- LuckyLucOnBass
09 Feb 2013 05:50
I'm working on an 83 KZ550. I got it to fire up a few weeks ago. Then it would only click the solenoid. The solenoid worked, but was in bad shape. I replaced it with a new solenoid for self assurance. I still wasn't getting power out of the starter. But power was definitely making it there. I took out the starter and jump it to a battery charger. It didn't spin unless I started it with my hand. Even then, it whined and screeched.
So I took it apart and sure enough it was worse than I thought. The bushing were completely burned to a crisp. A ton of ash poured out too.
Needless to say, I need a new starter. I read on another post to use a Honda Mitsuba SM-220 starter. What's everyone's opinion on that? Do you use them? Other options are buying a rebuild kit, a used starter, a rebuilt starter, or a close to OEM starter. I'm leaning to the Honda starter.
Thanks,
LL
Thanks,
LL
bass player, bike rider, hockey fan.
1983 KZ550 M1
1983 KZ550 M1
- MFolks
Re: Opinions on a new starter motor...
09 Feb 2013 16:01
The Mitsuba may not fit your bike, as I've advised Kz1000 and Kz1100 owners that it will fit their bikes. Look here for possible rebuild kits and replacement starter motors:
Starter Motors
www.nationsautoelectric.com/Kawasaki.html
www.whitedogbikes.com/cat--Kawasaki-Star...-Starter-Motors.html
www.ricksmotorsportelectrics.com/starters.php
Starter Motors
- LuckyLucOnBass
11 Feb 2013 01:09
You were right, it did not fit. I borrowed one from a friend. The mounting bolts were too wide.
I'll go with a rebuild kit for now. For $18, it's worth a try.
1983 KZ550 M1
1983 KZ550 M1
