KZ400 Complete shutdown
  • Duckhole
  • Duckhole's Avatar Topic Author
30 Jan 2013 21:15
#570012
Hi, I was at a red light and my bike just shutdown completely. I was wondering what a few things I could check before I pay someone to look at it. What would cause the motor and all electrical components to stop?
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: KZ400 Complete shutdown
30 Jan 2013 21:22
#570014
Fuse.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: Duckhole
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
30 Jan 2013 22:02
#570017
Nebr_Rex wrote: Fuse.
I'll 2nd that. The same thing happened to me. I always carry spares.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Motor Head
  • Motor Head's Avatar
30 Jan 2013 22:19
#570022
Yep, Blown Main Fuse.
  • Duckhole
30 Jan 2013 22:31
#570024
Might have found the culprit, hopefully replacing this guy will save me a monster headache!! Thanks everyone, lesson I wont forget. :blush:
  • Motor Head
30 Jan 2013 22:35
#570026
Clean up the Fuse Clips, and make sure they hold the fuse tight. If you have a Volt meter, check for a drop in Voltage across the Fuse. If there is, it is Dirty/ Loose. Then it will heat up again, and come loose at the cap like that one. If it blows out at the small metal strip inside the fuse, then its a Short in the wiring.
  • Duckhole
30 Jan 2013 22:42
#570027
Great info thanks!
  • ThatGPzGuy
30 Jan 2013 22:56
#570029
I've been able to get home by just connecting the two half moon ends together sans fuse. Beats walking...
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • H1Vindicator
  • H1Vindicator's Avatar
31 Jan 2013 10:40
#570074
But you risk melting the wiring harness.
31 Jan 2013 11:01 - 31 Jan 2013 11:01
#570077
H1Vindicator wrote: But you risk melting the wiring harness.
+1 ! Especially if you have not identified the problem that caused the fuse to blow. It could be anything from simply a faulty fuse to a dead short in one of the high-current circuits. If the latter, it may actually start a fire in the harness. Be careful. Ed
Last edit: 31 Jan 2013 11:01 by 650ed.
  • bountyhunter
  • bountyhunter's Avatar
31 Jan 2013 19:39
#570142
Duckhole wrote: Might have found the culprit, hopefully replacing this guy will save me a monster headache!! Thanks everyone, lesson I wont forget. :blush:
FYI, glass tube fuses should be thrown away and replaced every couple of years. They do go bad and blow at the worst times. I carry some in the tail section of my bike. I blew a main fuse one day when I stepped on the brake, there was no wiring problem the fuse just went away.
  • ThatGPzGuy
31 Jan 2013 20:57
#570151
True. You have to be careful. In my case it was obvious the glass fuse was the culprit since it was in pieces.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
