Handlebar controls swap
- Revboyz
30 Jan 2013 15:08
Has anyone swaped out the controls from a late model zr6/zzr 600 to a kz model (84 kz700). I have a project bike that I'm working on and would like to swap out the controls.
Thanks
Kevin
Thanks
Kevin
Why leave well enough alone!
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
- StreetfighterKz
Re: Handlebar controls swap
30 Jan 2013 15:34
I swapped in a right side switch from a ZX12...or R1 (they're the same) and an aftermarket left switch onto my '78 Kz1000 and will be swapping a similar right switch and a ZX6RR left switch onto my '76 Kz900. It's pretty easy if you have the wiring diagrams for each bike.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Revboyz
30 Jan 2013 17:15
Yeah true I have to get the 07 zzr600 wiring diagram. I opened both controls from both years to see what was what. The diagram makes it a lot better to work with. I guess I would just have to buy the connectors match the wiring and plug and play. How did yours turn out streetfighter?
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
- StreetfighterKz
30 Jan 2013 23:56
It was straight forward from what I can remember (I did it around 10 years ago). I used bullet connectors so I didn't have to modify the stock main harness.
I'm most likely going with a completely custom harness on my 900 and will use nice OEM style connector blocks when the time comes.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Revboyz
09 Feb 2013 10:50
That is what I'm going with I just bought some OEM connectors. I just have to look it over. I'm also going with acewell speedo. (more wiring).
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
