2-pin connector, where does it connect to???
Re: 2-pin connector, where does it connect to???
25 Jan 2013 00:54 - 25 Jan 2013 00:58
Another from FILEBASE:
www.kzrider.com/filebase/doc_download/51...iring-diagram-part-1
Last edit: 25 Jan 2013 00:58 by Patton.
- dookiebrown20
25 Jan 2013 00:55
Is just a piece that is missing. I bought it from a friends dad. He is a pot head who thought he could dissemble and clean the bike. And put it back together. Between him being on "cloud 9" and me getting the bike, I guess some stuff happen to be missing.
1980 Kawasaki KZ1000G Z1 Classic
- The Gringo
- ¡Usted no necesita otra motocicleta!
25 Jan 2013 00:56
Just a guess and since I no longer own my G-1 I can't check to be sure but that could be for the fuel pump. If the FI system has been removed from your bike it is no longer needed.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- dookiebrown20
25 Jan 2013 00:59
@Motor head, thanks that diagram helped ALOT! Now I just need a replacement fuel pump. Is this something I can find at a local store? Or is this an online only item? You guys are awesome by the way, THANKS sooo much
- Motor Head
25 Jan 2013 01:05
So from what you've described, you have the REST of the Injection system? This includes a lot of pieces. Do you have a Manual, hopefully the Kawasaki Factory Manual for the Bike?
Fuel pumps from Kawasaki I don't think are available. But there are plenty of pumps that can do the job, but may take both some re-plumbing and an adjustable pressure regulator.
- MFolks
25 Jan 2013 01:06
The stock fuel pump pressurized the FI system to 33 PSI, when the air flow meter door moved, the pressure went to 35 PSI. Make sure the fuel lines will stand the pressure, otherwise you may have a low volume flame thrower on your hands......
- dookiebrown20
25 Jan 2013 01:09
Yup still have the fuel injector and the original service manual. Just need a new fuel pump and or maybe a new regulator
- MFolks
25 Jan 2013 01:09
Here's some websites to look at:
Fuel Pumps & Regulators
www.fuel-pumps.net/gsl393.html
www.mpsracing.com/products/MPS/FuelPumps.asp
www.airtexproducts.com/
www.summitracing.com/parts/msd-2225?part=msd-2225
You'll need a fuel filter installed before the fuel pump, and get creative in the plumbing for the new pump, fuel filter & pressure regulator. Also check the one way return line screwed into the bottom of the fuel tank. If it's sticking, the engine will run rich.
- Motor Head
25 Jan 2013 01:12
I think I would go back over to the Friends house and go through the garage, or wherever the bike looked to have been stored or worked on. You may find that fuel pump, and it might still work.
- dookiebrown20
25 Jan 2013 01:13
Much love and appreciation! Will check back in when I get things figured out.
- donthaveakawman
25 Jan 2013 01:15I'll be one to point at the obvious, What is #14 for 1000, Trebek?
- dookiebrown20
25 Jan 2013 01:43
It was #14! But now I how to figure out how to chose a new pump.
