Need opinion on Wiring Diagram
- MtStateMike
Re: Need opinion on Wiring Diagram
25 Jan 2013 10:49
Yeah, I noticed this morning it did not come out as well when I changed it to a Jpeg. I have a PDF version that is much better. Will try to attach it but it I can't I can email it if anyone wants to look at it.
92 KZ1000p
Lumberport, WV
Lumberport, WV
- Motor Head
25 Jan 2013 10:57
Might find it hard to post the pdf, I'd download a free screen capture software. Then you can capture the screen or a section of it. It can save it as a jpeg or other format, which is easy to post. Plus you can open it in Paint and add to it, or change it easily.
- MtStateMike
25 Jan 2013 11:04
Tried again to upload it. See if this is any better. If not like I said I can email it at an attachment in the PDF version, which is very good quality.
Attachment kz1000pWiringDiagram.png not found
92 KZ1000p
Lumberport, WV
Lumberport, WV
- Motor Head
25 Jan 2013 11:07 - 25 Jan 2013 11:16
Much better. Do you also have the Factory Police diagram? Ignition switch contacts, there is a box at the bottom that shows the contacts of the switch in different positions and the wire colors Stock.
Blew it up a bit more.
Last edit: 25 Jan 2013 11:16 by Motor Head.
- MtStateMike
25 Jan 2013 11:09 - 25 Jan 2013 11:12
Yes, I have the wiring diagram. That was how I made this one without all the wiring for the Police lights, siren, etc.
What I can't figure out is why I can't get an power out of the Blue and Red wires coming from the ignition. I can't find where it has any other leads into the battery from those two wires. I have checked and double checked.
92 KZ1000p
Lumberport, WV
Lumberport, WV
Last edit: 25 Jan 2013 11:12 by MtStateMike. Reason: Added more info
- Motor Head
25 Jan 2013 11:20 - 25 Jan 2013 11:43
Does your diagram show the Switch contacts in a Box at the bottom of the diagram? The one I posted does not.
Ok did some research, found other models which take the same Ignition switch and found a diagram with the contact info.
The Blue, Tail light 1 wire comes off of the fuse panel, through the factory lighting switch, then to the ignition switch, then with that contact closed in Position 1 will supply power out to the red. So you need a input To the Ignition Switch on the blue to have power out on the Red.
Last edit: 25 Jan 2013 11:43 by Motor Head.
- MtStateMike
25 Jan 2013 18:54
awesome. thanks for the research. atleast that tells me why i wasn't getting power out of it. thanks again.
i actually got everything hooked up by running my tail & headlight off the blue coming out of the fuse box. turn signals, brake light and illumination lights off the brown out of the fuse box. got it all hooked up and tried the starter. It turned over, so all is good right now. going to pull the wires out now and put a cover on it as a complete harness.
92 KZ1000p
Lumberport, WV
Lumberport, WV
- wireman
25 Jan 2013 20:11
Id eliminate kill switch and wire headlight into ignition accessory side so it comes on with key,I like to make it obvious as possible that Im coming down the street and the headlight helps even during the day
- Gabe42
02 Feb 2013 18:30
I have heard that these bikes can wired and ran off of two wires through the whole bike. Does anybody know how to do this? And what are the pros and cons to doing so?
02 Feb 2013 21:54Is there a prize for correctly guessing who this was heard from? :lol:Gabe42 wrote: I have heard that these bikes can wired and ran off of two wires through the whole bike. Does anybody know how to do this? And what are the pros and cons to doing so?
