Need opinion on Wiring Diagram
- MtStateMike
1. I am wanting to lose the Engine Run Switch - so that is why you won't find it. Just going to operate off the ignition key for power.
2. I am cleaning up the handlebards so the Starter Button is being moved to the left side with only the Turn Signal Switch.
3. On the right side will be the Headlight Switch.
Let me know if this will work or am I wasting my time on trying to eliminate the Engine Run Switch?
I can't get my diagram to post, will work later on getting it in here. Sorry.
92 KZ1000p
Lumberport, WV
- MFolks
- Thank you received: 540
www.cyclepsycho.com/kz1000p/kz1000p.html
My feeling is to leave the run/stop switch in the circuit, as it's a safety, in case you need to kill the engine like right now.
- Thank you received: 2829
MFolks wrote: If you need it, here's the wiring diagram from Kawasaki for the police bike:
I'd keep it too; you never know when you might need it. Maybe it could be changed to something like the button switch in the pic below if the stock switch looks too big...
Attachment 00000_2013-01-23.jpg not found
- MtStateMike
92 KZ1000p
Lumberport, WV
- MtStateMike
Attachment kz1000prewire.jpg not found
Here is my wiring diagram without the Engine Run Switch. MFolks I used the diagram you sent me last year to come up with this, losing all the police wiring that I didn't need.
92 KZ1000p
Lumberport, WV
- MFolks
Some heatshrink splices and wire terminals:
(Ultimate Performance Heatshrink Terminals)
(Butt Connectors vs. Bullet Connectors)
(Heatshrink Terminal Installation)
(Heatshrinkable Crimpable Terminals)
- MtStateMike
92 KZ1000p
Lumberport, WV
- MtStateMike
92 KZ1000p
Lumberport, WV
- MFolks
For a stronger starter motor, read this:
Using A Honda Starter In A Kawasaki
Buda from the www.kzrider.com forum wrote:
Will not turn the engine over....10.25 10 1 comp 1170 cc......took starter out and ran it with a battery....the starter spins strong but starts to squeal after a second.....also the shaft has a lot of play side to side. Bad starter I’m guessing What do you guys think?
Took the starter apart.....the bushing on the drive end is cracked
Using a Honda Mitsuba SM-220 Starter in the Kz (copied from the KZ rider website)
The CB F's used 2 different starters. Look for the one marked .8kw. They also have one that is .7kw. This owner noticed a difference when he installed his. He read that you can remove the outer housing, and rotate it. this will re-align the outer power terminal, to a better location. if you don’t do this, you will need to grind some metal from the chain cover to gain clearance. Also install a heavier gauge wire to the starter , I’d recommend 6 AWG(American Wire Gauge) welding cable with the correct terminal ends to match the treaded studs for the solenoid and starter motor. Don’t forget the cable from the battery to the solenoid.
The stock KZ starter is .6kw in size
www.stockers.com/index.php?dt=HS-29 (Mitsuba SM-220)
Buda Wrote:
Thanks MFolks, Just ordered the rebuild kit before I read your post....If that doesn't work out I'll give the Honda starter a shot.
Got a the Honda starter MFolks recommended (SM 220 12 volt 0.8 KW) on ebay...hell of a difference.....Turns over like the plugs are missing....I'm sure the new battery doesn't hurt, but its a hell of a difference.
- MtStateMike
Attachment not found
Attachment kz1000pWiringDiagram.jpg not found
92 KZ1000p
Lumberport, WV
- MtStateMike
92 KZ1000p
Lumberport, WV
- Motor Head
- Thank you received: 391
MtStateMike wrote: Here is a better version of my diagram I came up with. I have the headlight hard wired to always be on. I have taken all of the police wiring out of it. So I think I have it figured out now. Started running wire today and will work more tomorrow on it with hopefully a test start and check to see if my battery is charging.
Your diagram is not very readable as posted. Hard to make out the Lettering for each component. Also the size is small, I've opened it in a photo viewer to try and see it better. Also Paint to re-size it. Maybe go back and clean it up a bit, so the Text comes out better.
